Tire size question
Old Aug 2, 2011 | 11:30 PM
sumit88's Avatar
sumit88
Default Tire size question
So I just ordered by CCW Classics, 18x10F and 18x12R
For up front would you suggest 275/30 or 35 Nitto Invo's
FYI I am going to run 295/35/18 Invo's out back
Old Aug 3, 2011 | 12:27 AM
wamara's Avatar
wamara
Cruise-In II Veteran
I'd do 35 profiles up front, but that aside, IMO 295's on a 12" wide wheel is way too small. Good luck whatever you end up choosing to do.
Old Aug 3, 2011 | 01:53 AM
striper's Avatar
striper
I've got Classics on my car. 18 x 10 in front using 265/35-18 Vredesteins. 18 x 11 in rear using the stock size 295/35-18 Vreds. If you use 12" wide rear rims you're going to need wider tires, 295 are too narrow. My tires front and rear are as wide as you want to go with their respective rims. I would suggest going down to 11" rear rims, not only for the tire size issue but the 12"s will stick out of the wheel well. My tires sit exactly at the edge of the fender openings and do not rub anything inside either (unless you're planning for flared rear fenders). I would call CCW and speak to John about his recommendations.
Old Aug 3, 2011 | 01:57 AM
striper's Avatar
striper
If you call CCW you can get your wheels with tires already mounted. Since you're in NJ, it'd be a long ride but you could see my car in person before you make your final decision.
Old Aug 3, 2011 | 02:02 AM
50thpro's Avatar
50thpro
i have ccw wheels also but 19's in the rear. i did front 275x35x18 and rear 325x30x19
Old Aug 3, 2011 | 02:04 AM
50thpro's Avatar
50thpro
and there Nitto
Old Aug 3, 2011 | 02:40 AM
JETZ's Avatar
JETZ
295's on a 12, is called 'streched'. Go 305, on an 11.
Also...if you plan on upgrading to big brakes in the future, you have to order them to be built that way now! You can't do that after the fact.
To Tire size question
