You don't even have 20k miles on it and you are basically stock... I don't see how anything could be worn with "typical" driving...
Any chance you have an aftermarket shifter? My guess would be your shifter has moved and is no longer aligned properly.
Did you miss a shift a some point?
No aftermarket shifter. With the exception of some spirited backroad driving I just drove it around town. I've only owned it for about 5 months.
Originally Posted by zeevette
I don't think that shifter misalignment can cause the grinding sounds that Ser is having. Just as a old school test, you could try double clutching on shifts. Not very helpful, but could lead to syncro problems.
I can still get into third easy but it grinds on the way in. Double clutching doesn't help. LIke I said in the OP, even if i'm idling and shift to third immediatley after pushing the clutch in, it'll grind. But if I clutch in and wait a second or two it won't grind if it's undre 1.5k rpms.
@ 81c3: I know that RPM is great with our trans but I wanted to see if there where any places closer to me. If not I suppose I'll have to buy a level VI and send them my trans for the discount. I'll still need a shop here in souther cali to install the trans though.
