Cooling Mod
Old Aug 6, 2011 | 02:01 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Default Cooling Mod
We've had a heat wave the last few weeks here in Houston and ambient temps have been around 110-112 degress. I haven't been comfortable with how warm my car has been running with the A/C off. On the highway I'm seeing 205* and in stop and go traffic it has been 219*. Before the heat wave, ambient temps were 101-105* and with A/C off on the highway I was seeing temps of 196* and stop & go traffic, 212*. So I finlly bit the bullet and tried to do the front plate mod. Cut hole in bumper and removed radiator shroud, but I chickened out when it came to cutting a hole in the license plate cover. So I scrapped the project and put the license plate cover over the hole I cut in the bumper and called it a day because I was too lazy to put the shroud back on. I took the car out today in the same ambient heat wave temps and WOW! what a difference. On the highway I saw 178* in freakin 111* outside temps and it went as high as 183* and in stop & go traffic I saw 180*. That's a ginormous difference. I think the radiator cover was trapping all that heat...
Old Aug 6, 2011 | 02:09 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Cool
Old Aug 6, 2011 | 02:29 PM
jrose7004's Avatar
jrose7004
Glad that simple mod has worked for you.
Old Aug 6, 2011 | 04:02 PM
Big difference in the temps.
Old Aug 6, 2011 | 04:39 PM
Tyteflows's Avatar
Tyteflows
interested in seeing exactly what and where you cut, do you mind throwing up a few pics please, thanks!
Old Aug 6, 2011 | 04:53 PM
dbaker's Avatar
dbaker
Yep,I would like to see a pic of that too!
\db2
carolina
Old Aug 6, 2011 | 05:01 PM
woodman300's Avatar
woodman300
St. Jude Donor '15
\db2
carolina
Old Aug 6, 2011 | 07:26 PM
Darkness1988's Avatar
Darkness1988
Yeah pics! Im in Dallas having the same problem. Mines getting in the 230s
Old Aug 6, 2011 | 07:47 PM
Joe_Planet's Avatar
Joe_Planet
Hot enough for ya?
Old Aug 6, 2011 | 08:05 PM
HawnHog's Avatar
HawnHog
Make or buy the license plate cover that has the center cut out and screened in. I bought a clear cover (they are cheap), cut out the center section, painted the inside of the cover to match the color of my car (black), hot glued a screen on the inside of the cover and ya got one easy mod. Took a hole saw and cut three holes in the back where the plate attaches.
Old Aug 6, 2011 | 08:06 PM
Darkness1988
Originally Posted by Joe_Planet
Hot enough for ya?
Ha yeah!!
HawnHog's Avatar
HawnHog
Old Aug 6, 2011 | 08:10 PM
TriplBlk's Avatar
TriplBlk
Sorry, I just had to
Old Aug 6, 2011 | 09:25 PM
All_Motor_C5LS6
No pics yet, but its simple. I started doing the front plate mod and aborted mid way into it. The center section of my bumper where the license plate go was cut open but I didn't cut the cover piece because I was too nervous. So I placed my cover back on covering up the center section I cut open. I didn't reinstall the radiator shroud and left it off. Its now sitting in the corner of the garage. The shroud was trapping heat in the raditator/condensor area while stopped at stop lights. With the shroud removed the heat can escape thus the car stays cooler in hotter temps.
Old Aug 6, 2011 | 09:31 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Here are a few of mine
This pic shows a good shot of my intercooler!
Old Aug 6, 2011 | 10:26 PM
redrckt97's Avatar
redrckt97
what intake do you use with no shroud (OP)?
Old Aug 6, 2011 | 11:06 PM
Qwik01's Avatar
Qwik01
Wouldn't removing that shroud make the engine bay get real dirty?
To Cooling Mod
Old Aug 6, 2011 | 11:10 PM
Must_Have_Z's Avatar
Must_Have_Z
I agree. And the shroud and radiator cover kinda help hold everything in place too. I just installed a Honker today, and without the shroud and cover, the radiator and cooling fans are kinda loose... Sounds a little sketchy to me!
Old Aug 6, 2011 | 11:14 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Interesting
Old Aug 6, 2011 | 11:36 PM
All_Motor_C5LS6
Vararam
