New owner needs help
Zuti
Read the link provided in the earlier post and check the codes yourself.You'll find that there is a WEALTH of knowledge here, so always try to use the advanced search function first. You can usually find 5-10 threads on any given subject.
As far as the fuel codes, not sure where the fuel level sensor is located. I do know from changing out my passenger side tank sending unit/fuel pump that there is a level sensor on that side and it will affect your fuel gauge.
Techron is a good place to start though.
Only you are going to take time in dealing with your car and as you become used to doing things to your car, the times will go down, but you will know it was done right. No stripped oil change bolt, fresh oil actually put in. Tires properly torqued, ETC................
Good luck with your car.......................
hopefully this link will be useful for you...
http://www.stengel.net/diccodes.htm
BTW, congrats on giving it a try and figuring it out!
Nothing like this place. Love the Vette! Love the Forum!
