[Z06] overheating???
Old Aug 9, 2011 | 11:05 PM
silver_z06's Avatar
silver_z06
Default overheating???
wats up, I got a little problem, my car seems like its overheating, when I'm at a stop light my gauge reaches up to 250 my fans turn on but that seems like its not helping, and when I start driving my temp. drops to 200, and I wen come to a stop light reaches to 250 again, this happens everytime I stop. any idea what this can be, or anyone encounter this problem too??? any info is welcome. thanx
Old Aug 9, 2011 | 11:50 PM
Vetterthanyou2's Avatar
Vetterthanyou2
Mine bumped up to 230 sitting in the sun@idle. A bit concerning, but as much as it may seem crazy, modern vehicles and these aluminum blocks seem to take to the heat pretty well(whereas my fat *** in this 105 degree heat DOES NOT!!!)lol
Old Aug 10, 2011 | 12:44 AM
Z06ster's Avatar
Z06ster
I'm not an expert in these matters but just my thoughts...
1) Are your fans coming on at all? If they are not coming on, you would see temps raise whenever you're at a stand still, but go down as soon as you're moving.
2) It wouldn't hurt to install a lower temperature thermostat
On a different note, I got a DeWitts radiator and the difference was literally night and day. The DeWitts radiator is probably 3 times wider than stock. Before the change out, on a 100 degree day here in Southern California, my temps could get up to 235. Now, this summer, my temperature barely goes over 200! Very much worth the money in my opinion.
Old Aug 10, 2011 | 10:32 AM
silver_z06's Avatar
silver_z06
my fans do turn on, dnt know exactly at what temp. turn on but I know they come on, yesterday day when I got home I left my car on pop my hood to see if they come on because I thought it was my fans but when I pop my hood they were on
Old Aug 10, 2011 | 12:54 PM
enigma94's Avatar
enigma94
Sounds like the radiator is clogged and not allowing the fans to pull enough air through to cool the water. I'd check to see you dont have anything stuck in front of the radiator and make sure that its clean from dirt. If you dont do this at least a once a year you will be seeing your temp gauge creep up.
Old Aug 10, 2011 | 02:37 PM
speedyhawk101's Avatar
speedyhawk101
I agree with ENIGMA94. My Z06 temps would start to climb when sitting at stops lights when I first bought the car. I cleaned out A PILE OF CRAP from the front of the radiator and the problem went away.
Old Aug 10, 2011 | 02:45 PM
Vette53's Avatar
Vette53
Another vote to check the radiator for blockage...
Old Aug 10, 2011 | 03:59 PM
silver_z06's Avatar
silver_z06
thats exactly what I'm gonna do as soon as I get home, do u think it might be a good idea to flush my radiator, havent flushed it since 08
Old Aug 10, 2011 | 06:11 PM
geoffl's Avatar
geoffl
Mine was at 230 in stop and go traffic a few weeks ago. Cleaned out the radiator and AC condensor and it now runs 190 on the highway and 205 in traffic. Lots of stuff in mine.
Old Aug 10, 2011 | 09:57 PM
Laser Guided's Avatar
Laser Guided
I need to clean out my radiator soon as well, I've never done it since i bought the car (about 10 months ago). Any tips/tools that I should use that would help out?
Old Aug 11, 2011 | 01:47 PM
enigma94's Avatar
enigma94
A flush wouldnt be a bad idea specially if you are running 3 year old coolant, But I dont think a flush will fix your overheating problem. Also, I personally have had issues with burping the system free of air so make sure you evacuate all air in the system to avoid air pockets that will cause you to overheat as well.
Having a compressor will help out greatly so you can use the compressed air to blow out the radiator. Some people have found specific brushes to work as well. My radiator was so bad I had to remove it and take it down to a do it yourself car wash and used the high pressure hose to blow the fins out. You must be careful in any rout you go though as the fins on the radiator will bend VERY easily. I'm sure there are some write ups on how people have done this in the past as its a very frequent issue with these cars.
Old Aug 11, 2011 | 02:22 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Cooling fins are clogged with sand/dirt. Blow it out with a air compressor, tons of crap comes out.
Usually a big wad of crap is sandwiched between the ac condenser and the radiator.
Be careful with the fins, their delicate.
Best of luck.
39 days of 100+ heat in dallas...............................
Old Aug 11, 2011 | 03:14 PM
50thpro's Avatar
50thpro
sounds like you need to replace the thermostat
Old Aug 11, 2011 | 04:16 PM
silver_z06's Avatar
silver_z06
I replaced the thermostat and it seems that fixed the problem not too sure yet, I also replaced the coolant with purple ice, it seems pretty steady at 205, but I'll keep watching it for the next couple weeks,
Old Aug 11, 2011 | 08:04 PM
Techsan's Avatar
Techsan
Best of luck.
Make sure you blow the air from the clean side out the dirty side, that way it doesn't clog it anymore.
Old Aug 12, 2011 | 01:10 PM
enigma94's Avatar
enigma94
I wouldn't guess it to be the thermostat, I bet your radiator is still clogged, unless you've eliminated that as being your problem. Usually when its a thermostat you wouldn't have the overheating only when sitting still, and usually the car doesnt cool back down while driving. Unless the unit is just not opening till 200+ degrees (stock is 187) which is rare as most fail either fully open or fully closed, then I highly doubt its going to be just a thermostat.
To overheating???
