ccw classic front rims hitting?
Old Aug 15, 2011 | 08:34 AM
mulalleybs's Avatar
mulalleybs
Default ccw classic front rims hitting?
Self explanatory.. when I cut the wheel all the way to the left or right it rubs, if I go slow enough it will almost stop the car like turning in a truck with 4x4 on. Is this common with the 18x10 fronts? solutions?
Thanks,
Brett
Old Aug 15, 2011 | 11:45 AM
mulalleybs's Avatar
mulalleybs
do I need spacers?
Old Aug 15, 2011 | 12:30 PM
EV2DEMON's Avatar
EV2DEMON
Where do they rub? I've got them on my car and they really aren't even close to rubbing anything up front.
Old Aug 15, 2011 | 12:57 PM
mulalleybs's Avatar
mulalleybs
You know, I was looking at it. It looks like it rubs the front brake ducts. It doesn't appear to contact any other part of the body, so I'll investigate a little more after work. Any additional input would be awesome.
Old Aug 15, 2011 | 01:17 PM
Bluefire's Avatar
Bluefire
I had a similar issue. My factory ordered CCW's rubbed when I got them. Long story short... The tires were hitting two bolts I used to install the HID ballasts onto the wheel wells. :o
Old Aug 15, 2011 | 11:36 PM
striper's Avatar
striper
Same size fronts and I think only a couple of times have I ever turned the wheel hard enough to hear something rub. It didn't bother me so I never checked it out.
Old Aug 17, 2011 | 10:05 PM
mulalleybs's Avatar
mulalleybs
I guess its hitting the.. lower a arm?
Old Aug 18, 2011 | 10:50 AM
mulalleybs's Avatar
mulalleybs
Any idea why? Need an alignment maybe?
Old Aug 18, 2011 | 06:44 PM
mulalleybs's Avatar
mulalleybs
bump
Old Aug 18, 2011 | 07:01 PM
Bills03Coupe's Avatar
Bills03Coupe
What size tires are you running? Extra tire width can easily cause rubbing.
Old Aug 18, 2011 | 07:05 PM
AU N EGL's Avatar
AU N EGL
Your car lowered?
I run 18x12 CCW Classics with 18x305/30 up front. If I turn lock to lock the wheel rubs the brake duct.
Easy solution, DONT TURN LOCK TO LOCK and dont make those tight slow speed turns.
Wide tires up front will fell like a pig in the mud at slow speeds, YES but at high speeds on a road course it like its on rails.
Track tires left street tires right
Wheel rub on the Brake duct
Old Aug 18, 2011 | 08:02 PM
Sherpaboy's Avatar
Sherpaboy
Running CCW's 19x10/275's lowered and no issues
Old Aug 18, 2011 | 09:33 PM
mulalleybs's Avatar
mulalleybs
275 up front. its no where near the brake duct, the rim hits my lower a arm on both sides.
Old Aug 19, 2011 | 03:18 PM
tlove32's Avatar
tlove32
I have 18" classics with 275mm tire, and it only hits on passenger side with a full-lock right-hand turns. I have no issue with the driver side or with with left-hand turns.
To ccw classic front rims hitting?
