Digital HVAC Display Question
Old Aug 17, 2011 | 06:48 PM
IDM's Avatar
IDM
Default Digital HVAC Display Question
Does turning the passenger **** on your HVAC change your air temp reading?
On my car it does not but the drivers side **** does.
I can't remember if it was always this way, havent driven a C5 for a while.
Old Aug 17, 2011 | 06:53 PM
Tyteflows's Avatar
Tyteflows
working as intended
Old Aug 17, 2011 | 07:02 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
It's just fine. Passenger side has no reading.
Old Aug 17, 2011 | 07:11 PM
IDM's Avatar
IDM
not real helpful when you have replaced the indicator ***** with chrome ones
Thanks guys
Old Aug 17, 2011 | 10:52 PM
No, it does not change the reading, but it does adjust the passenger side temp up to I believe approximately +/- 6* F. If the driver-set temperature is set at 60F (16C) or 90F (32C), turning the passenger **** has no effect because the system is locked at a maximum setting.
Old Aug 18, 2011 | 02:31 AM
DeeGee's Avatar
DeeGee
Spot on as usual Jack
Old Aug 18, 2011 | 09:09 AM
jrose7004's Avatar
jrose7004
Nope, the driver side is in control.
Old Aug 18, 2011 | 11:35 AM
jim993's Avatar
jim993
I would also note that on a couple of occasions, turning the **** on the driver side TOO FAST confused the computer in my car, resulting in no heat.
For the last year, I have been turning the **** more slowly with no repeat of the problem.
Corvette Action Center has an informational post from GM on this symptom FYI.
Old Aug 18, 2011 | 01:09 PM
IDM's Avatar
IDM
very good to note because I always keep it on 60 so my passenger **** doesnt do anything at that point if its locked
thanks guys we have disected the c5 hvac, what nerds we are. Now can someone take mine out and resolder one led bulb that is starting to blink. Guess I am not good at soldering or my suspension is too stiff.
Old Aug 18, 2011 | 01:47 PM
mikesvette1's Avatar
mikesvette1
Jack thanks so much for the information. I though mine had stopped working but i have had it at 60 so now i know what is wrong, saved me a few bucks to because i was going to tear into it this winter, again thankyou so much.
To Digital HVAC Display Question
