Erratic and odd indications
Old Aug 24, 2011 | 09:13 PM
Ruidoso Bill's Avatar
Ruidoso Bill
Default Erratic and odd indications
Just finished a 3,000 mile round-trip in my C5, it was awesome. One odd thing happened that scared the heck out of me. I was passing and the auto downshifted and accelerated, then all of a sudden it started flashing reduced power, active handling, security tire pressure etc. even the airconditioner started blowing warm air, it continued until I pulled over, shut it off and when restarted all was well. I do have a diablo tune in it but other that that and corsa tips it is bone stock, any ideas?
Old Aug 24, 2011 | 09:46 PM
Quicksilver98's Avatar
Quicksilver98
Default Grounds or battery
I would check your ground connections. There are several listed in the service manual. Or do a search in this forum. I am sure you will find several threads. Next have your battery load tested....even one a little weak will do strange things in a C5. Again many threads on that topic too.
Old Aug 24, 2011 | 09:53 PM
Ruidoso Bill
Thank you for the suggestions, had no idea where to search.
Old Aug 24, 2011 | 10:02 PM
Bill Vett's Avatar
Bill Vett
Did you hit a bump??? I would check the wiring in the drivers side A pillar and the door. Pull back the accordion tube and check the wires that are in the pillar, There are two bundles. Unplug and clean the contacts and put everything back. Here's a thread that will help with grounds and the door wiring .....
http://forums.corvetteforum.com/c5-t...tion-long.html
This is a large thread, but contains a batch of info.
Old Aug 24, 2011 | 11:24 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The door jam accordian tube is a real possibility here but the very first thing you need to do is to pull your codes and post them all. Be sure to include the "H" or "C"s with each.
Old Aug 25, 2011 | 12:23 AM
Ruidoso Bill
Think I got them all, here goes:
U1255H
U1301H
U1088H
U1096H
U1016H
U1064H
U1300H
U1626H
U1176H
U1160H
This car had 9300 miles when I left on my trip.
Old Aug 25, 2011 | 01:27 AM
Pewter Scooter's Avatar
Pewter Scooter
Any code that ends in H is a history code (something that has occured in the past) but is fine now.
U1255H Serial Data Line Malfunction
U1301H Class 2 Circuit Shorted to Battery
U1088H Loss of Communications with SDM
U1096H Loss of Communications with IPC
U1016H Loss of Communications with PCM
U1064H Loss of Communications with BCM
U1300H Class 2 Circuit Shorted to Ground
U1626H ???? can't find this one, but P1626 is Theft Deterrent System Fuel Enable Circuit
U1176H Loss of Communications with RFA
U1160H Loss of Communications with LDCM
I'd start with taking my battery to my local Interstate dealer and have it load tested. They'll do it free, and it just takes a few minutes. Once I was confident I have a healthy battery, and good battery connections, I would sure suspect an intermittent loss of a ground connection somewhere.
Old Aug 25, 2011 | 02:39 AM
DeeGee's Avatar
DeeGee
The U codes are symptomatic of a power glitch. You can clear them down but I doubt any will come back any time soon.
You had good advice already. Its worth checking anything which might cause a power interruption so battery state, battery leads, grounds and door accordian connections would also be my suggestion.
If it's any consolation, it happened to my car many years ago just before the battery died and it never reoccurred. Could be just a one-off.
Old Aug 25, 2011 | 08:57 AM
dgrant3830's Avatar
dgrant3830
I agree...check the door accordian tube as there's a connector there with a serial data buss wire in it that will get lose over time and can cause these problems. The 1300 code has me concerned as its attached to the TCS system although I'm thinking your posting of U1300H should have been C1300H. Clear all of the codes now and see if any come back.
Old Aug 25, 2011 | 10:57 AM
Bill Vett's Avatar
Bill Vett
Please start with making sure the battery if charged over night, then look to the tube to the drivers door. If you notice you have a LDCM code (left door control module) This may be the main issue. Everything passes through the drivers door. I had the same problem several years ago and it was in the wires in the A pillar. Since that one time I have never had the problem return. Make sure all the wires are pushed into the plug, make sure all contacts are clean and snug, and not grounding/ shorting. .
Old Aug 25, 2011 | 11:21 AM
Bill Vett's Avatar
Bill Vett
I found the post in the electrical sticky for you to read.
http://forums.corvetteforum.com/c5-t...n-long-18.html
Page #18 Post #356
Old Aug 25, 2011 | 12:20 PM
navyvetteran's Avatar
navyvetteran
Check your fuse box for any loose fuses, that solved my similar problem.
Old Aug 25, 2011 | 12:23 PM
Bill Vett's Avatar
Bill Vett
Originally Posted by 8VETTE7
The information on the page that you reference was later updated by the author, Bill Curlee, after he and I exchanged several PM's. The correct information is on page 30 and in post #586
http://forums.corvetteforum.com/c5-t...n-long-30.html
Then scroll down to post #586. Note the correction date of 2/2011. Unfortunately there are numerous other posts with the same descriptions and pictures in the thread that have not been updated. But the bared wires in the pictures are actually speaker grounds and do not need to be coated. The black connector in the door is usually what is the problem. Loose connections, bent pins and or corrosion on the pins.
Sorry for any mis information, I was told by my tech that the bare wire with clear coating was ok as you said, a speaker wire drain. I did find cleaning and making sure that no wires were loose/ not pushed in all the way and all contacts clean and tight did correct the issue. I did this to both sides inside A pillar and the drivers door. Bill
Old Aug 29, 2011 | 01:18 PM
Ruidoso Bill
I thank you all for the replys, I was on a retreat all weekend and will start checking things out today. I will start with the battery, it is the origiginal on an eight year old card and then the door accordians next.
Old Sep 3, 2011 | 08:44 PM
Ruidoso Bill
I first replaced the battery, the one in there was the original and 8 years old. It had the same erratic indications all over again, guess the battery wasn't the cause. Started with the grounds behind the headlights, they were both clean but I touched them up anyway. Did the battery to chassis ground, it was a little dirty but not bad either. Did both the door "accordian" connectors sprayed with radio shack contact cleaner. Did a quick test drive and got on it and so far no codes or erratic behavior.
The only 78 series I could find was from walmart, hope that is sufficient for now, I intend to order a redtop optima soon.
To Erratic and odd indications
