wide body handling
Adding L5 widebody fenders normally means wider wheels and tires which can and will effect handling.
BUT, I will say if I take traction control "off" and then accelerate through a turn...it's coming loose, very manageble....but it would be the same even without wider rear stance.
in most cases the car will tramel on over cracks in the road. Low speed handling will suck, high speed handling with the proper alignment will be good.
I have a different wide body kit.
in front I run 18x12 with 18x305/30
and in back 18x13 with 18x335/30 with 3/8" spacers on each side.
GM T1 suspension.
Low speeds the car handles like a pig waddling in the mud.
High speed corners of 80+ mph is like a slot car on rails.
Now it is a track car and the front has -2.0 camber and the rear is -1.5 camber
GM T1 suspension.
"pig waddling in the mud" = understeer? Slow Response? so...corning sharp canyon roads at 40-50 should respond well assuming the corning forces are similar to your 80 mph turns. Do the tracks you run have sharp turns similar to a canyon road? How does it handle in that 40-50 mph range.
Its kind of hard to think of the right questions to ask, but I just want to make sure I don't slide off a cliff if I go widebody lol
I'm guessing
I'm probably more sensitive to handling and setup than most but I'm very happy and greatly appreciate the additional traction.
I'm guessing
Pig in the mud, is under steer = what we call here in NASCAR land = push.
Handling is to do with alignment and tire size
Tires first:
the close the tires are to the same size the better the handling
Most guys have too narrow a front tire and too wide a rear tire.
yes I know we like big wide fat rear tires.
let say 315s Good over all rear tire performance size
that would be 18x315/30 or 18x315/35
to match for better performance the fronts
18x295/35 but no less then 18x285/35
to go to a 335 rear you need a 305 or 315 front.
again 18s all around. 19s are too heavy and 20s are for parking lot queens. 19 and 20s are just too heavy and wheel weight has a lot to do with performance and handling.
when there are mis match or big width difference between front and rear tires, = understreet or push.
guys on the road course use what we call a square set up
18x315/30 front and rear on 18x10 front rims and 18x11 rear rims.
-3.0+ degrees front and -2.0+ degrees rear camber
alignment:
for better handling look at an aggressive street alignment such as
front
camber: -1.0* to -1.5*
caster: Max but equal
Toe: 1/32" OUT
Rear
Camber: -0.75*
Toe: 1/32" IN
no cross
No ranges
Exact.
HTH a bit
here is a good example of extreamly high speed cornering: Not me
wheels IRRC are 17x315/35 on all four corners
VIRginia International Raceway http://vimeo.com/20208440
Road Atlanta http://vimeo.com/17511121
Not me driving
Enjoy
I am in too....
