touch up paint
Old Sep 1, 2011 | 10:57 AM
woodvette03's Avatar
woodvette03
Default touch up paint
If anyone needs some touch up spray paint and can't find it, look on ebay. I needed some torch red for my C5 but Duplicolor does not make the spray anymore. I found someone on ebay who had a stock of it cheap.
Old Sep 1, 2011 | 12:26 PM
31coupe's Avatar
31coupe
Has anyone tried the one advertised on ebay for the 2003 Annni red color?
Old Sep 1, 2011 | 05:38 PM
leahy's Avatar
leahy
i just got some paint from touchuppaintonline.com a couple weeks ago.
Old Sep 1, 2011 | 05:41 PM
JeffreyDurbin's Avatar
JeffreyDurbin
I had good luck with Advance Auto Parts because by the time you add in shipping ebay isn't that cheap on stuff like that.
Old Sep 1, 2011 | 07:23 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
I'd be pretty weary of buying paint online unless you ask the right questions. IE: enamel, vs base coat/clear, color match, etc.... I just ordered slate gray for my subaru from a local company. Their spray bombs are "made to order." and take about a day to make but they are pretty spot on, not like some of the generic stuff you will find online. The cost was about $25 since it was enamel based and will be used for a couple of trim pieces. That being said, I have a spot on my bumper that I need to redo on the vette, and it will cost $35 for the spray bomb, and $15 for the clear...add tax and I'm close to $70. Not to bad I suppose, but I might get a professional quote from a friend to see what the price difference will be. Sorry didn't mean to jack the thread, just wanted to make people aware that you might be able to find something better locally. The price might be a few dollars higher, but isn't your vette worth it???
Old Sep 1, 2011 | 07:50 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Just go to any GM dealer, and have them order it...it will be the right match using the right color code. its about 15 dollars and takes about a week. But its the right stuff. Some automotive paint suppliers can mix up some paint and put it in a rattle can.. that cost about 30 dollars for a 16 oz can... Its not as batch correct as the stuff you get from a GM dealer.
Old Sep 1, 2011 | 07:53 PM
woodvette03
the reason i look on ebay was b/c duplicolor does not make spray in the color i needed anymore. i just happened to find someone who had a stock of it. only paid $16 for 2 cans with shipping.
Old Sep 1, 2011 | 08:20 PM
Vette5.5's Avatar
Vette5.5
As mentioned, places like automotivetouchup.com. can put some spray cans together for you. This is the real deal two part factory paint package, so you'll need to clear top coat it for gloss. Actually Dupli-Colors usually the single part laquer. Maybe consider getting raw product/thinner and use a small Preval sprayer. These are basically a glass jar, with a gas charged nozzel on top, and work quite well. A shot a replacement steering column with with of these, and no way you could ever tell it wasn't factory.
Old Sep 1, 2011 | 08:27 PM
Jet Moto's Avatar
Jet Moto
How much area are you touching up?
If you are touching up rock chips, the best touch paint that I ever used is Dr. ColorChip. After touchup, it looks factory smooth. None of the ugly texture you get by brushes.
A little expensive, but well worth the money.
You can buy them online at http://www.drcolorchip.com
Old Sep 1, 2011 | 08:49 PM
Vette5.5's Avatar
Vette5.5
Another thing of mention is the paint code, but sounds like you already have it. It's usually the the last numbers on the glove box sticker after BC(base coat) CC(clear coat) U(upper). If your car had lower accent paint, would be an L(lower) code too. In the case of my black car it's 8555. Just add the industry WA, and it's officially WA8555 for my car.
Old Sep 2, 2011 | 08:08 AM
barblarry93's Avatar
barblarry93
I found torch red for my 2003 at Advanced Auto
Old Sep 2, 2011 | 08:18 AM
Here are some sources you can look at:
Corvette Spray Paint Sources:
www.corvettepaintcodes.com
www.expresspaint.com
www.paintscratch.com
www.automotivetouchup.com
Old Sep 2, 2011 | 09:11 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I get mine from the GM dealer.
Old Sep 2, 2011 | 03:09 PM
31coupe's Avatar
31coupe
thank you for your responce, I will check with a pro
To touch up paint
