Need help with HID lights
Old Sep 2, 2011 | 08:52 PM
rwlc5's Avatar
rwlc5
Default Need help with HID lights
I installed the HID projtor lights from JW Motoring about 2 years ago. The car is only driven about 1500 miles per year. The lights have had very little usage. One light will not light. However, the high beam in that lens will light. Do you think it is simply a burned out bulb? Or could it be something with the ballast? I suppose it could also be a loose connection somewhere, but I have not been able to check it out yet as I just noticed this today and I was attending the inaugural Baltimore Grand Prix all day and for the next 2 days. Thanks.
Old Sep 2, 2011 | 09:16 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
have you tried emailing Jhonathan?
Old Sep 2, 2011 | 09:35 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Check your connections.
Old Sep 2, 2011 | 09:47 PM
damilleniumboy's Avatar
damilleniumboy
I say loose connection as well.
Old Sep 2, 2011 | 09:50 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Is the car running when you fire the low beams ?
the ballasts require quite a bit of load to fire, usually they will not fire unless the engine is running.
Old Sep 2, 2011 | 09:51 PM
damilleniumboy
You might want to check for a pinched cable some-where as well because of the light housing going up and down.
Old Sep 2, 2011 | 10:01 PM
rwlc5's Avatar
rwlc5
Car is running when I turn lights on. I have not contacted Johnathan yet.
Old Sep 2, 2011 | 10:09 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Try taking out the good bulb and placing it in socket that's not working properly and check the results. If the light comes on, and both high/low beam work then you need a new bulb. I doubt it's a connection issue or ballast, regardless inspect the bulb and filaments.
Old Sep 3, 2011 | 08:24 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
First check the wiring to be sure nothing came loose.
Then I would swap ballasts. They tend to go before bulbs do. That will tell you if the bulb or ballast is out.
Old Sep 3, 2011 | 09:03 AM
cruisemon's Avatar
cruisemon
I had a similar issue with lights that had been in place about 18 months. The ballast failed.
Charlie
Old Sep 3, 2011 | 05:36 PM
_zebra's Avatar
_zebra
if you've ever touched the bulb with your skin, it's probably dead.
but check your connections first, and then swap the ballast from the other side
Old Sep 3, 2011 | 05:46 PM
PoVette's Avatar
PoVette
I agree w JW, swap the ballasts.
Old Sep 3, 2011 | 07:31 PM
Phanni's Avatar
Phanni
Try turning the lights on and off several times and see if it fires up.
If it flashes and then goes out it could be a battery issue.
Old Sep 4, 2011 | 11:04 PM
stol3n's Avatar
stol3n
same problem here.
no wires pinched or any loose connections. my car only gets driven a couple times a month. if I had to estimate it only has a total of 8 hours night driving on it since the HID install and my left light will not light up.
-I also have the JWMotoring kit.
Old Sep 6, 2011 | 08:38 AM
rwlc5's Avatar
rwlc5
Finally had a chance to look for the problem. The entire HID bulb came out of the socket and was dangling down behind the light. Good news is that it still lights. However, I can't see how to put it back into the socket and make it stay in. Is this bulb supposed to have some tabs like a normal bulb that fit into an opening and then gets twisted to lock it in? I can't see where there are any tabs or ears sticking out around the bulb that would lock in under the housing when twisted. Maybe they some how broke off and that is why the bulb came out, but it doesn't look like anything broke off of the bulb housing. Any ideas?
Old Sep 6, 2011 | 09:01 AM
Phanni's Avatar
Phanni
Look at the side that the bulb seats correctly, use that as an example.
Old Sep 6, 2011 | 09:05 AM
rwlc5's Avatar
rwlc5
I thought of that, but it is a real PITA to do that. You have to take off the headlight cover and then remove the bolts in the headlight bracket so that the assembly will tilt forward on order for you to access the rear where the bulb installs.
To Need help with HID lights
Old Sep 6, 2011 | 01:38 PM
rwlc5's Avatar
rwlc5
Talked with Johnathan. There should be tabs on the bulb socket that lock it in place just like a regular bulb. Apparently they broke off somehow. He is going to replace the bulb at no cost. That is the kind of vendor that you want to do business with!
Old Sep 6, 2011 | 11:54 PM
NYY1980's Avatar
NYY1980
rwlc5, check the amp relay. Im willing to bet thats the problem. Let me know
Old Sep 7, 2011 | 05:07 PM
rws.1's Avatar
rws.1
I would swap the ballasts side to side...
Mine failed at 18 months....
