Well....this bites.
Sep 4, 2011 | 08:51 AM
St. Jude Donor '05, '12-'13, '15-'16, '21
Well....this bites.
The glue held up for about 7 yrs but finally let go on one of my gauge bezels. I saw it this AM when I went out for an early morning drive. Fortunately, not a tough job to fix......but still a PIA. I guess it will give me the chance to see how the other bezels are holding up.
Sep 4, 2011 | 09:21 AM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Super glue them suckers. Just don't put the cover back on for a bit.
Sep 4, 2011 | 09:49 AM
Quote:
Originally Posted by
JW@JWMotoring.com
Sep 4, 2011 | 10:05 AM
JW@JWMotoring.com
I put super glue "dots" all the way around spaced about 1/2" apart. Use tweezers.
Btw, in this case "a bit" is code for 27 minutes, not to be confused with 12 1/2 cents.
Sep 4, 2011 | 12:08 PM
GGEENN
Sep 4, 2011 | 02:57 PM
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
mine
came with superglue!
Sep 4, 2011 | 04:14 PM
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Mine came off even when applied with superglue on my 97 C5 several times over the 4 years of ownership, mostly in cold weather.
So when I bought my 02, I was sure these pieces were not on my Mod list.
Sep 4, 2011 | 09:48 PM
That sucks. Good luck tearing the dash apart and getting the bezel back in place.
Sep 4, 2011 | 10:35 PM
I have used 3m exterior body tape on my Z for almost 6 years now and the vert for over a year in hot cold and 25k miles of driving. Fingers crossed I never have an issue. On an upside they get easier each time.
Sep 4, 2011 | 10:49 PM
Sep 4, 2011 | 11:09 PM
One word: silicone. You just have to be careful with the distribution as it can ooze if you use too much.
"If it can't be fixed with silicone...it can't be fixed."
Sep 5, 2011 | 12:45 AM
I had to get back into my cluster 3 times to fix bezels that came loose, typically in the cold weather... Check the others REALLY well!
