EBCM: New or Rebuilt?
Old Sep 8, 2011 | 05:08 PM
31ECHO's Avatar
31ECHO
Default EBCM: New or Rebuilt?
From following the Forum, it appears that the OEM EBCM's are lacking in reliability. Are the rebuilt units more reliable ?
Old Sep 8, 2011 | 06:17 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
supposedly yes. That's what absfixer.com claims on 01-04 units.
Old Sep 8, 2011 | 07:17 PM
AntonioZ06's Avatar
AntonioZ06
I'm running a ABSfixer rebuilt one (had code C1214). So far so good
Old Sep 9, 2011 | 05:22 AM
Just going by the feedback posted here on the forum, the ones repaired by absfixer seem to hold up well. And a lot cheaper than buying a new one.
Old Sep 9, 2011 | 09:11 AM
AtiLLa's Avatar
AtiLLa
According to the research that i did on the forum a month or so back when i had EBCM issues, it may depend on the code as to what actually gets "repaired". I saw where sometimes the 1214 code only requires re-soldering of the relay contacts and NOT actually replacing the relay. However, some codes like 1232 or 1233 would require the replacement of some transistors. These units apear to have several parts that are prone to fail at any given time. If a unit goes bad and only one part is repaired to make it operational again, then it could still fail another day when one of the other "weak" parts go bad. I don't know if any of the repair vendors go through a unit and completly replace all of the weak components and make the repaired unit better than any other unit. My guess would be that only the faulty component would be repaired to get the unit operational again. But even so, a repaired unit can be purchased for about half of what a new one costs so you can gamble that it will not fail again and put the savings toward other things. Plus, there is no guarantee that a "new" unit will not fail just like your original one. Unless there was a design change or something, a new unit will still have the same weak components as all of the original ones that are in our cars now. What i decided to do was purchase a repaired unit (from Marc at VetteNuts) to get my car back operational and then send my old unit off for repair. Then i will keep the repaired unit for a backup incase i have some issues again. That is still cheaper than buying a new one. So far, the one from VetteNuts is working well and i have not had any issues with it (thanks Marc).
atilla
Old Sep 9, 2011 | 10:42 AM
cdkcorvette7's Avatar
cdkcorvette7
Same here...
Old Sep 9, 2011 | 11:29 AM
MX621's Avatar
MX621
Had code 1214 as well, followed the EBCM DIY repair post in the tech section.. Followed the directions, fixed it myself.. Pretty easy actually .
Old Sep 9, 2011 | 11:33 AM
dougbfresh's Avatar
dougbfresh
If you go to the absfixer site he actually has an upgrade to the electrics to keep it from getting fryed.
Old Sep 9, 2011 | 03:01 PM
31ECHO's Avatar
31ECHO
atilla
That's good feedback. Thanks.
Old Sep 9, 2011 | 07:48 PM
RamAirTA's Avatar
RamAirTA
From: I'll Keep My Guns , Freedom And Money. You Keep The Change. FL
Module Master.com
I had them fix mine a couple years ago. Fast turn around and works perfectly. 5 year warranty too.
To EBCM: New or Rebuilt?
