Diagnostic codes
Sep 13, 2011 | 08:48 PM
2nd Gear
Diagnostic codes
looking to find out what the codes mean. is there a place to type them in and find out what they mean?
10PCM P1416 HC
A0LDCM B2282H B2284H U1064H U1016H
A1RDCM B2283H B2285H U1064H U1016H
A6SCM B2860H
60IPC B1527H U1160H
Sep 13, 2011 | 09:33 PM
http://www.stengel.net/diccodes.htm
they all look like history codes ...thats what the "H" is. "C" is current, so clear all codes and check them again
P1416 AIR System Bank 2 is the passenger side Air Check Valve...use search for that easy fix (cleaning)...hope that helps
Sep 13, 2011 | 09:36 PM
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Codes with an H after it is history and no longer active, Code with a C after it is current and active.
P1416 is the following code: Secondary Air Injection (AIR) system Bank 2
It could just be a faulty check valve. I would also check the line to make sure there is no damage
Sep 13, 2011 | 09:38 PM
I got mine here:
h = history code and c = current code
Good luck.
Sep 13, 2011 | 09:41 PM
pete, repete, & rerepete.... Ya'll beat me to it. Im getting slow............ but not my driving.
Sep 13, 2011 | 09:52 PM
i beat ya'll to it ...lol
Sep 13, 2011 | 09:55 PM
Sep 13, 2011 | 10:03 PM
Nice heels,......I mean wheels.......
Sep 14, 2011 | 09:43 PM
Thanks Vic.....David did you get it figured out?
Sep 15, 2011 | 02:13 AM
The P1416 is your only current code. Loks like a good clean with carb cleaner could be the answer. Try this thread:
http://forums.corvetteforum.com/c5-t...p1416-dtc.html
U codes are symptomatic of power glitches. Add to that you have 4 battery fault codes on the seat modules. I'd say you had a battery problem at some stage. Is your battery topped off? If not it might be worth an overnight charge. Also check your battery leads are clean and tight.
Once you've done that, clear the codes down and see if any come back
2002 ,
b2860h ,
c6 ,
code ,
codes ,
corvette ,
diagnostic ,
http ,
reading ,
wwwstengelnetdiccodeshtm ,
z06
