Marto1955
Old Sep 14, 2011 | 12:00 AM
Marto1955's Avatar
Marto1955
6th Gear
Default Marto1955
OVERHEATING 2002 Corvette Changed water pump, 160 thermo checked relays still clicking with 12 volts ( can they still be bad if still clicking) Is so I'll repace them. 9yrs old anyway. temp stayed at 220 idling drove down the road 300yrs topped out at 260 and shut her down. took the radiator out and cleaned it had quite a bit of grass and road debris. Shot water into it and had flow out the other end, but that doesnt mean the vains are clogged up inside . My next step was to purchase a new radiator. Instead of having it serviced, spend the money on a NEW One, and forget about it. ANYBODY HAVE ANY IDEAS?
Old Sep 14, 2011 | 07:53 AM
chris308's Avatar
chris308
fans coming on?
Old Sep 14, 2011 | 09:19 AM
dougbfresh's Avatar
dougbfresh
Do a cooling system pressure test.
Old Sep 16, 2011 | 07:31 PM
Marto1955's Avatar
Marto1955
6th Gear
Default Overheating 2002 Corvette
Yes Chris Fans are on! And all relays are good. Purchased a new Radiator today. After I get it I'll cut the old one open to see if vains are clogged up! I was going to get a custom one from Ron Davis radiators but I'm out of work right now . Everyone ought to check them out they do a NICE JOB!! all alum and 2 rows of fins BEAUTIFUL . Ill do it when I get back to work ($899) if I dont like the temp. I dont like my engines runnin in the 220 range too hot.
Old Sep 16, 2011 | 08:46 PM
glowworm_76039's Avatar
glowworm_76039
Sounds like you still have air in the cooling system to me. I had the same problem after a cam swap. A friend that was a lot smarter than me told me to fill the reservoir up to the top and let the system push the air out over the next couple of days and that worked.
You could also still have a thermostat problem. I replaced my stock thermostat with a 160 from JEGS and it was bad out of the box. Took me a month to figure out why the car would overheat sitting still but not while moving. Swapped it out and the problem was solved.
There are posts in the forum for testing thermostats, could be an easy fix.
Good Luck!
Old Sep 17, 2011 | 09:42 AM
Marto1955's Avatar
Marto1955
6th Gear
GLOWWorm I tested the thermo before I installed it. it opened up thank you
Old Sep 17, 2011 | 09:53 AM
Marto1955's Avatar
Marto1955
6th Gear
I'm going to fill through the top radiator hose with water pump hose connected. Closed thermo should stop the flow. Then stick a hose in the top of water pump and fill the block hopefully this will get most of the air out before we start. Then fill the rest at flow tank, See what happens
Old Sep 17, 2011 | 10:02 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
The LS1 is famous for getting air in the system, Did you burp the system correctly?
According to the service manual:
1. Fill the system through the surge tank opening.
2. Fill half the capacity of the system with 100 percent DEX-COOL® coolant.
3. Slowly add clean drinkable water to the system until the level reaches to the base of the neck.
4. Start the engine.
5. Idle engine for 1 minute.
6. Install surge tank cap.
7. Cycle the RPM, idle to 3000 in 30 second intervals until engine coolant reaches 99°C (210°F).
9.Shut off the engine.
10. Refer to step 3 above to remove the surge tank cap.
11. Start the engine.
12. Idle engine for 1 minute and fill surge tank to 1/2 inch above COLD FULL mark on the radiator surge tank.
13. Install the surge tank cap.
14. Cycle the RPM, idle to 3000 in 30 second intervals until engine coolant reaches 99°C (210°F).
15. Shut off the engine.
16. Top off coolant as necessary, 1/2 inch above FULL COLD mark on the radiator surge tank.
17. Rinse away any excess coolant from the engine and the compartment.
18. Inspect the concentration of the coolant.
Old Sep 17, 2011 | 10:31 AM
Marto1955's Avatar
Marto1955
6th Gear
Thanks MR. BILL
To Marto1955
