skip shift
Old Sep 28, 2011 | 09:00 AM
black match box's Avatar
black match box
Default skip shift
I want to put in a skip shift eliminator . My Question is. the instructions say to disconect the neg. term. when I do this will I loose any memorie from the cars computer?. Like the key fob, ect. ect. ect. I know people have done it so please chime in. thanks. black match box.
Old Sep 28, 2011 | 09:38 AM
xpunter83's Avatar
xpunter83
I did mine without disconnecting the battery..
Old Sep 28, 2011 | 09:43 AM
wkndwarrior's Avatar
wkndwarrior
no problems, quick and easy
Old Sep 28, 2011 | 09:50 AM
bumble-z's Avatar
bumble-z
I agree. No need to disconnect the battery.
Old Sep 28, 2011 | 09:54 AM
b.lee's Avatar
b.lee
I disconnected my battery this weekend, after reinstalling it the key fob took about 5 presses on the lock button and then it started working.
Old Sep 28, 2011 | 02:41 PM
johnwhoss's Avatar
johnwhoss
My mechanic programmed out the CAGS. No more first to fourth forced shift and the message no longer lights up on the dash. He asked if I wanted him to change the dash light feature to a shift light coming on at a certain RPM, but I said no.
Old Sep 28, 2011 | 06:28 PM
When I installed the CAGS eliminator on my '00, I did not disconnect the negative cable on the battery. Just unplugged the connector at the tranny and plugged in the CAGS eliminator unit and sealing cap.
Old Sep 28, 2011 | 06:37 PM
Silverback51's Avatar
Silverback51
Originally Posted by 8VETTE7
Did mine the same way.
As for disconnecting the battery, I would only be concerned if you have the theft lok for the radio activated and don't remember your password.... Otherwise you should have nothing to worry about.
Now I'm concerned.
I just bought my 2002 C5 last Saturday, and so far I have found out that I did not get the key to the wheels. Now I read that there is a theft lok for the radio and it requires a password. What happens if the battery is disconnected and I do not have a password? Am I SOL?
Old Sep 29, 2011 | 08:46 AM
wkndwarrior
Originally Posted by Silverback51
Now I'm concerned.
3 things here......
1 you are in the right place, i have gotten more info......valuable info from here than at either of my local gm dealers
2 use the search and see if there are similar posts....yes it can be time consuming and frustrating but give it a good go before you ask and get the bombardment of "USE SEARCH"....trust me i spent hours using search and could not get what i was looking for and still got a little "USE SEARCH" hazing.....after that in the thread acknowledge you have used the search...hazing will be somewhat less
3 start your own thread......only because the title of this one is about skip shift.....people are not going to find your question about radio and wheel locks buried in a skip shift thread......
that being said welcome to the forum
To skip shift
