How do you remove/replace the traction control button?
Old Oct 4, 2011 | 08:18 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default How do you remove/replace the traction control button?
Once the plate is removed, do you remove the entire black electronics box? If so, how? Do I press in the tabs on the sides, use a screwdriver? I don't want to break anything. Anyone do this? This one is sticking and needs to be repaired or replaced...
Old Oct 4, 2011 | 09:20 PM
zesstey1's Avatar
zesstey1
I Used small paper clips, use small screwdriver or pin knife to pry open by clips then insert paperclip to hold open work your way around. There are two small pucks that may be out of shape in the switch.
Old Oct 4, 2011 | 09:44 PM
01magnetic01's Avatar
01magnetic01
did the same thing using very small screw drivers
Old Oct 4, 2011 | 10:32 PM
MSG C5's Avatar
MSG C5
Thanks Guys! The paperclip idea worked like a charm!
To How do you remove/replace the traction control button?
