Im curious as to why you guys think im having too much overteer, causing the rear end to bust loose.
I was going through a roundabout, nothing TOO crazy and i gave it a little gas. maybe 1/4 throttle or so and the back came out a little.
This is concerning because I might be doing autox later this month and would useless to even go out there.
Heres some info on the car itself.
-18/19 rims with 305/30/19 on the rear. About half life of Michelin pilot sport ps2's.
-A4 (it didnt downshift or anything)
-Stock sways.
-Stock endlinks with bushings worn to hell
-Probably tired worn F45 shocks (149k)
-Over 400 rwhp.
Mine was like that when the rear alignment was bad. (Shop replaced a worn tie rod end and didn't align it.) And yes they have tie-rods in the rear too.
Tie rods are good. Alignment should also be fine. i just had the front end done because of lowering the vehicle and never having it done caused terrible tire wear.
Did they do a 4 wheel alignment? Front and REAR tie rods are good? I had one of the adjusters come loose after the first alignment, might want to check that out also. Good luck
This is what happens when you have rubber band tires on a car. A tire needs sufficient sidewall to flex under cornering. The more you have, the better communicative a tire will be.
With a 305/30/19, you will have tons of grip but are likely to just let go without warning. Given that you were on the street, they probably were relatively cold causing them to snap without warning.
Put some sensible wheels and tires on the car and it will communicate with you better.
High stall torque converter might encourage this.
Size of roundabout. Smaller diameter = easier to break loose
Temperature makes a big difference with my car (toyo 888's)
Road conditions(dusty,coolant or oil on the road)
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
You've been given a lot of good advice/info, but, I would definitely improve the two below, BIG TIME! If you go on a spirited run with good twisties, you'll catch hell in curves. That's what I would think .
-Stock sways.
