2001 Service Active handling Light on
Old Oct 6, 2011 | 03:48 AM
JWR11's Avatar
JWR11
Cruising
Default 2001 Service Active handling Light on
Recently my 2001 6 spd displays the "Service Active handling" light after I drive for about 20 miles. I have cleared the codes but it will return again after a short period of time. The car runs and handles perfectly. As a novice, I would appreciate any suggestions from other members that have encountered the same. Many thanks!.....JWR11
Old Oct 6, 2011 | 10:04 AM
Dave68's Avatar
Dave68
Default This looks familiar....
Have you looked at the codes?
http://www.southerncarparts.com/corv...des-ex-12.html
If your EBCM has failed and you don't want to dig out the failed component(s), you can still remove it and send it out to be repaired for no more than $150. Here's my procedure for doing this:
http://www.conceptualpolymer.com/Ele...l%20Module.pdf
Old Oct 6, 2011 | 12:51 PM
JWR11's Avatar
JWR11
Cruising
Thanks!! - I will pull the codes and post them tomorrow or next when I am done work.
Best regards.....JWR11
Old Oct 6, 2011 | 03:12 PM
Mr.Nubain's Avatar
Mr.Nubain
From: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
This happens to my 01 alot as well. I'd like to get it fixed, but I'm not too worried about it. It has been throwing BS codes since I bought it 5 years ago.
Old Oct 6, 2011 | 03:23 PM
87SAM's Avatar
87SAM
Not sure this is considered BS codes.
Old Oct 6, 2011 | 03:59 PM
Dominic Toretto's Avatar
Dominic Toretto
This happens not often to my car as well. I just turn the car off and back on and the message goes away.
-Alex
Old Oct 7, 2011 | 12:04 AM
Dave68's Avatar
Dave68
During the time period when my "service active handling, ABS, and traction control" warnings were being displayed, I almost demolished my car. I stepped on the gas pedal when the ground was a bit wet, the car spun around and almost headed down a steep hill and into oncoming highway traffic. With all the "nannies" working, that would've never happened.
I mention this because we tend to get used to our nanny helping us out at times, often without our knowing we've been "corrected".
For $150 or less, your C5 can be much safer. Don't wait too long!
Old Oct 7, 2011 | 12:33 AM
lh4x4's Avatar
lh4x4
Do simple things first. If your steering wheel is not straight then the steering wheel sensor will not make contact and cause the code to come up. This happens sometimes after a wheel alignment.
Sometimes when the battery starts to get weak then the code is thrown.
If neither of those two, then into the dealer you go.
Old Oct 7, 2011 | 10:07 AM
JWR11's Avatar
JWR11
Cruising
Dear friends - Many thanks for your replies and the website that you kindly directed me to.
I finally had some time this morning and pulled the codes. They are as follows ;
28TCS - C1287H & C1288H
BO-RFA - U1000H & U1064H.
Your generous time is greatly appreciated!!
PS - I have been trying to post a picture of my Corvettes next to my threads as you all
have done, but no luck. My computer inexperience is really showing through. Sorry.
Best regards.......JWR11
Old Oct 7, 2011 | 01:10 PM
JWR11's Avatar
JWR11
Cruising
Default Service Active Handling Light On - 2001 6 spd
Thank you 8Vet7....the steering wheel is perfectly centered and the front alignment seems to be correct. The Vette has 47,000 miles on it and I am only on the second set of tires (all4). They have abundant tread left and will remain in service for quite some time. It also tracks straight going down the road. Appears as if I should investigate your tip on the steering wheel sensor?.......Many thanks!
To 2001 Service Active handling Light on
