Another Catch Can install!
Old Oct 8, 2011 | 02:48 PM
sfc rick's Avatar
sfc rick
Default Another Catch Can install!
Just added one today. Heres the pic.
Old Oct 8, 2011 | 03:03 PM
Nice looking catch can Rick - what brand is that?
Old Oct 8, 2011 | 03:06 PM
Mtlfusion's Avatar
Mtlfusion
Yes please share, I've never seen one like that!
Old Oct 8, 2011 | 03:13 PM
sfc rick's Avatar
sfc rick
http://cgi.ebay.com/ebaymotors/CHROM...item33697f3246
Old Oct 8, 2011 | 08:50 PM
Monkey D. Luffy's Avatar
Monkey D. Luffy
looks good
Old Oct 9, 2011 | 01:59 PM
sfc rick's Avatar
sfc rick
Works well! Just checked it today after one run of about 75 miles and noticed a few drops in the bottom of the can. I can only imagine how much has been pooling in the bottom of my intake over the thousand of miles! That's why I would only see a puff of blue smoke on the rare occasion when the oil pooled enough and eventually was enough to find it's way into the combustion chamber.
Old Oct 9, 2011 | 08:26 PM
chrisk92's Avatar
chrisk92
Suspended by request 16 May 2012
how hard is it to install one?
Old Oct 9, 2011 | 08:39 PM
sfc rick's Avatar
sfc rick
It's simple...BUT, and it's a big BUT......you do have to make the bracket to bolt it to the head. It's an easy job for the handy with tools type of guy. Just buy some 1 1/2" flat bar from Lowes or Home Depot, or your local hardware store and drill the mounting holes and your done.
Old Oct 9, 2011 | 08:40 PM
chrisk92's Avatar
chrisk92
i see can i use this for a stock ls1 motor it kept saying with a turbo/s/c setup
Old Oct 10, 2011 | 11:21 AM
TrueBlueCoupe's Avatar
TrueBlueCoupe
Rick, do you have to remove the can to empty it?
Old Oct 10, 2011 | 11:28 AM
sfc rick's Avatar
sfc rick
You just unscrew the drain plug on the bottom of the can.
Old Oct 10, 2011 | 12:06 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
What year is your car? When looking at the vendor's offerings, none seem to apply to a 2002.
Old Oct 10, 2011 | 12:07 PM
VETJAZZ's Avatar
VETJAZZ
Nor to an 03.
Old Oct 10, 2011 | 01:30 PM
f6john's Avatar
f6john
Interesting that it's called a "universal" model then tells you what it will or will not be compatible with.
Old Oct 10, 2011 | 01:34 PM
chasboy's Avatar
chasboy
Oldtimer
Can the bracket be made of aluminum bar stock? Seems like it's a worthwhile mod.
Old Oct 10, 2011 | 01:44 PM
sfc rick's Avatar
sfc rick
Absolutely!
Old Oct 10, 2011 | 02:11 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Good luck with those Ebay catch cans. From what I have seen they do catch some oil but also let allot get through.
Pull your intake and clean it up real good then go back in a few months and check it again.
To Another Catch Can install!
Old Oct 10, 2011 | 02:31 PM
sfc rick's Avatar
sfc rick
Yea..... ok.
Old Oct 10, 2011 | 07:44 PM
chasboy's Avatar
chasboy
Oldtimer
[QUOTE=sfc rick;1578921839]Absolutely!
Rick, does that bracket attach to 'available' bolt holes already in the block?
Old Oct 10, 2011 | 07:46 PM
chasboy's Avatar
chasboy
Oldtimer
If they let a lot 'thru', where does it end up?
