Another Catch Can install!
Old Oct 10, 2011 | 09:43 PM
sfc rick's Avatar
sfc rick
[QUOTE=chasboy;1578925031]
Originally Posted by sfc rick
Absolutely!
Rick, does that bracket attach to 'available' bolt holes already in the block?
Yes, they are already in the head just waiting to be used.
Old Oct 10, 2011 | 09:52 PM
sfc rick's Avatar
sfc rick
Originally Posted by chasboy
If they let a lot 'thru', where does it end up?
That comment was just to give a scare warning to deter one from just jumping out there and buying anything from EBay on the chance occasion you didn't select the "premuim" product guaranteed to hold a quart of oil and never sputter another drop of oil into the intake opening.
It's just a catch can.... empty it when it gets full or otherwise it allows the oil to go where it always went in the first place...into the intake manifold, just like it originally did.
Old Oct 10, 2011 | 11:03 PM
chasboy's Avatar
chasboy
Oldtimer
Wait a minute!! I'm getting lost. The oil the catch can gets normally goes INTO the intake manifold to be burned with fuel? I somehow got the impression that the oil was pooling on top of the manifold.
Old Oct 11, 2011 | 07:43 AM
REZ1's Avatar
REZ1
if the drain is on the bottom...how hard is it to empty....must you remove it to empty ?
Old Oct 11, 2011 | 07:58 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Regardless if its at the top or bottom the can will have to be removed to drain. Really not hard at all, disconnect the inlet/outlet hose, remove the can from the bracket and drain, voila!
Old Oct 11, 2011 | 10:20 AM
Dave68's Avatar
Dave68
The top of the manifold provides a large surface area onto which oil droplets can settle. However, there is still plenty of airborne oil droplets that make their way into the combustion chamber.
Old Oct 11, 2011 | 10:26 AM
cdkcorvette7's Avatar
cdkcorvette7
Looks nice
Old Oct 18, 2011 | 01:55 AM
chrisk92's Avatar
chrisk92
Suspended by request 16 May 2012
Hey sfc rick which is the the inlet the top or bottom? i order the same one. the inlet is the bottom nipple and the outlet is the top? am i correct?
Old Oct 18, 2011 | 07:46 AM
sfc rick's Avatar
sfc rick
I bought a stainless steel kitchen mesh scrubber at the grocery store and inserted it into the can. This way it also helps catching more oil vapor and droplets using this media inside the can. The mesh thing cost me .79 cents.
Old Oct 18, 2011 | 11:59 AM
env00's Avatar
env00
Thanks for posting!
That truly is a nice looking catch can...very unique....I like...now if a vendor can make a complete kit for the C5 (with an option for a red colored top), I'd seriously consider buying one....
BTW they do have a red one:
http://www.ebay.com/itm/CHROME-UNIVE...item33697f327b
Old Oct 18, 2011 | 01:44 PM
oh1vette's Avatar
oh1vette
Several of the supporting vendors sell these complete with bracket and in various colors....
Old Oct 18, 2011 | 02:09 PM
1quick1's Avatar
1quick1
My intake likes the extra oil.
Old Oct 19, 2011 | 01:24 AM
  #33
chrisk92's Avatar
chrisk92
good idea outta try it thanks
  #34
chrisk92's Avatar
chrisk92
Originally Posted by env00
Thanks for posting!
that the one i bought it nice
Old Oct 19, 2011 | 03:33 AM
  #35
memmer's Avatar
memmer
that is one good deal as far as $$$$$ go.I paid well over $100.00 for mine
Old Oct 19, 2011 | 08:28 AM
  #36
sfc rick's Avatar
sfc rick
Use a turkey baster, unscrew the top cap and draw out whatever oil is there. SIMPLE! No removing or draining oil out the bottom.
P.S. DON'T let your wife catch you putting it back in the kitchen drawer!
