setting 1997 key fob
Old Oct 9, 2011 | 04:57 PM
Wilma's Avatar
Wilma
6th Gear
Default setting 1997 key fob
purchased a new key fob for 1997 corvette - how do you get the DIC to recognize it? Thank you for any help
Old Oct 9, 2011 | 05:33 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
!. Turn ignition on.
2. Turn radio off.
3. Press DIC RESET button.
4. Press OPTIONS until display is blank.
5. Press and hold RESET for 3 seconds.
6. Press OPTIONS until FOB TRAINING displayed.
7. Press RESET to begin programming sequence.
8. Simultaneously press and hold LOCK and UNLOCK buttons on
fob for 13 seconds. Message will appear on DIC when remote is
programmed.
9. Turn ignition off and remove key.
10. Test remote.
If you already have 1 you will need to reprogram all remotes.
Mr.Bill
Old Oct 9, 2011 | 05:37 PM
Mr.Bill's Avatar
Mr.Bill
Also if you don't have a manual for your car you can download one here.
http://www.c6registry.com/Technical/...97corvette.pdf
Old Oct 9, 2011 | 06:53 PM
2KFRC5's Avatar
2KFRC5
Repeat step 8, when prompted, for each FOB.
To setting 1997 key fob
