Battery Tender JR Warning
Old Oct 10, 2011 | 12:18 AM
duramaxsky's Avatar
duramaxsky
Default Battery Tender JR Warning
I have purchased 2 Battery Tender JRs for my Vette and Sky. The paper insert from the packaging makes a great warning device. I laminated mine and cut the laminate to the original shape for the most part. It fits between the wheel and column on both cars. I keep one in each car under the seat and install it when I hook up the charger. Now I won't forget to unhook it first. I also mounted outlets to my hoist so I have a handy place to plug them in.
Old Oct 10, 2011 | 01:41 AM
itzza427's Avatar
itzza427
Clever!! I just leave the cord hang out of the hood as I rarely leave it sit long enough that it needs to be hooked up!! Your little idea would be hard to miss!!
Old Oct 10, 2011 | 06:59 AM
Great idea. I have the Battery Tender Plus for mine and recently almost drove off with the cord still attached.
Old Oct 10, 2011 | 08:14 AM
realvc's Avatar
realvc
I need to remember to hook mine up.
Old Oct 10, 2011 | 09:18 AM
MAC5's Avatar
MAC5
I just leave the hood cracked open as a reminder.
Old Oct 10, 2011 | 09:35 AM
TOPCATHR's Avatar
TOPCATHR
i spliced mine into a cigarette lighter adapter and plug it into the 12v recepticle in the center console... it works great and theres no need to open the hood........
Old Oct 10, 2011 | 10:08 AM
Baldfart's Avatar
Baldfart
I do the same.
Old Oct 10, 2011 | 12:46 PM
hdkeno's Avatar
hdkeno
Originally Posted by Baldfart
I do the same.
same here
Old Oct 10, 2011 | 01:05 PM
hotwheels57's Avatar
hotwheels57
Good idea.
I use (BATTERY TENDER PLUS) the ring terminal harness hooked up permanently to the battery. I don't have to leave the hood open as the harness drops straight down where the male/female connection is made.
I forgot to disconnect it...ONCE...:o ...it's never happened again.
Old Oct 11, 2011 | 01:10 PM
navyvetteran's Avatar
navyvetteran
I put a piece of masking tape over key hole in ignition.
Old Oct 11, 2011 | 05:13 PM
TimmysCars's Avatar
TimmysCars
2nd Gear
Default Connectors
I do the same. Have the eyelet terminals connected directly to the battery posts. I use genius chargers instead. I like their connectors better. http://www.geniuschargers.com/accessories
Old Oct 11, 2011 | 05:32 PM
Luvmyride's Avatar
Luvmyride
5th Gear
Now thats funny. But good idea. I use genius. I perfer them over anything else. Nothing compares to the features and price.
Old Oct 11, 2011 | 11:18 PM
Jistari's Avatar
Jistari
I was a little worried when I first started connecting the car so I made up my
[IMG][/IMG]
Stop dummy! card
I dont use it anymore. In five years I have pulled out once with the cord attached and luckily the CTek quick connect plug I have routed out the side cove just disconnected.
To Battery Tender JR Warning
