[Z06] What size DR's?
Old Oct 10, 2011 | 07:45 PM
zblkr1's Avatar
zblkr1
Default What size DR's?
I have a bone stock 2003 z06 and i have an extra set of stock rims that i would like to put DR's on for the track. I was thinking about using the 17 inch fronts for the rear with some DR's on it? just curious on what people are running and what sizes.
thanks!
Old Oct 10, 2011 | 10:25 PM
novafx4's Avatar
novafx4
I've got the factory rims on my '02 with a set of 305/35-18 M/T ET Street Drag Radial II's mounted on them. The M/T's also come in 295/45-17 if you wanted to use the 17 inch front rims.
Old Oct 10, 2011 | 10:28 PM
zblkr1's Avatar
zblkr1
so i take it, it doesn't really matter? just preference?
Old Oct 10, 2011 | 10:39 PM
GARY2004Z06's Avatar
GARY2004Z06
The only tire you should consider given your setup should be 275x40x17s. Hoosiers will be lighter and have the most grip while MTs will provide more life and better traction if caught in the rain.
Old Oct 11, 2011 | 03:02 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
17s from the front work great on the rears. Before they came out with the drag radials I used the 17 inch et streets. Now I have 275 Mickey Thompson 17 inch Drs on my spare wheels. I use them mostly on the street as I have a drag pack for the track.
Old Oct 12, 2011 | 06:34 PM
MY03C5Z's Avatar
MY03C5Z
Will 16x8 stock camaro wheels fit on the rear of a C5z? Im looking to get a C5z soon, I have a set of my old stock 5 star camaro wheels with MT dr's in 255/50/16's I'd like to still use at the track only.
Old Oct 12, 2011 | 07:02 PM
princerobert1's Avatar
princerobert1
im using 315/35-18r toyo proxes tq
Old Oct 12, 2011 | 11:05 PM
SVTBAIT's Avatar
SVTBAIT
2015 C5 of Year Finalist
Interested to find this out as well.
Old Oct 13, 2011 | 08:44 AM
Sigforty's Avatar
Sigforty
It is hard to say without test fitting them. I know the CCW drag pack is 16 inch wheels and they are the smallest diameter wheel you can use and still clear the calipers. I would expect they should fit, but would question using an 8 inch wheel. The stock Z06 wheels are 10.5 inches in the rear and if you use a front wheel they are 9.5.
Old Oct 13, 2011 | 05:42 PM
PRE-Z06's Avatar
PRE-Z06
They won't fit with out a little massaging.
Old Oct 13, 2011 | 06:09 PM
MY03C5Z's Avatar
MY03C5Z
Is it because of the offset? Do you mean they would rub the inner fenders?
Old Oct 14, 2011 | 01:18 PM
PRE-Z06's Avatar
PRE-Z06
No, the diameter is too small to clear the calipers/bracket without doing some grinding.
Old Oct 14, 2011 | 02:37 PM
ACLR8R's Avatar
ACLR8R
How do you like them?
Old Oct 14, 2011 | 04:20 PM
princerobert1
to be honest my car has been apart for awhile and im just getting it back together its going on the dyno in a few weeks so i havnt drove it with the new dr's on but when i do here in a few weeks i let you know how they do
Old Oct 14, 2011 | 04:54 PM
homeless's Avatar
homeless
Default dr
My 03 z06 with bolt ons will run faster with 275-40-17 dr.I have 16 and 18 also.It 60 foot times are better with 17's
Old Oct 14, 2011 | 06:33 PM
MY03C5Z's Avatar
MY03C5Z
I'd like to run a 16" wheel because the taller sidewall is going to absorb more shock from the launch. I had a set of C5 thinspokes on my old camaro with 305 nittos on the back and I got a much better launch with 255/50/16 MT dr's on my old 16" rims. I searched this topic on google and from what I found you just need to clearence part of the ball joint for them to work. I didnt hear anything else about problems with the calipers.
Old Oct 14, 2011 | 08:56 PM
homeless's Avatar
homeless
Default dr
The 16'' inch rims will clear the calipers.But you have to grind the top of ball joint area for clearence.I belive the 16'' will work great for you.On our 98 auto c5 342 gears it run a 1.56 60 ft with et streets 255-50-16
Old Oct 15, 2011 | 12:07 PM
MY03C5Z's Avatar
MY03C5Z
Good to hear, my 16" MT dr's are like new, I was hoping to use them with my next car too. My 97Z I just sold was making around 375rwhp & with 4:10's these 255/50 MT's hooked up very well.
To What size DR's?
