Simple jacking question...
Old Oct 13, 2011 | 12:10 AM
jtmaddux's Avatar
jtmaddux
Default Simple jacking question...
With a lifting puck installed and a low profile jack can I simply lift one side at a time to remove 1 tire/wheel. In other words 3 tires/wheels will still be on the ground and 1 wll be raised just enough to remove....Thanks
Old Oct 13, 2011 | 12:14 AM
jrose7004's Avatar
jrose7004
Absolutely.
Old Oct 13, 2011 | 01:58 AM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by jrose7004
Absolutely.
Old Oct 13, 2011 | 02:04 AM
GBsC5Vert's Avatar
GBsC5Vert
From: LA/OC border, probably sittin' under the patio, by the pool...smokin' a cigar! SoCal
I don't know if this is true, haven't researched it, but when I took the 'vert in to have the wheels replaced, they opened the hood, trunk and doors. Worried about flexing maybe. Just a thought, like I stated, haven't researched that, but when I lift the Vett, that's what I do. Just prop them open, not all the way.
Old Oct 13, 2011 | 02:14 AM
DeeGee's Avatar
DeeGee
The C4 suffered from flexing of the frame which might be why some C5 owners are still nervous. there's a myth that says the doors have to be closed which is also untrue.
The preferred location is under the front frame but you can also lift using the front point on the rocker rails providing you use a lifting puck.
Heres a picture from the book.
Old Oct 13, 2011 | 02:16 AM
DeeGee's Avatar
DeeGee
Its a myth. You can lift with them open or closed but no need to open them
Old Oct 13, 2011 | 07:46 AM
dndrsn's Avatar
dndrsn
I had a C4 and jacked it up numerous times. They do flex. What I did was if I needed to have a door or the hood open after jacking the car I would open it first and leave it open until the car is back on the ground. The thing was don't open or close anything after the car is jacked up because of misalignment. Once back on the ground every thing lines up.
A C5 is very stiff and probably doesn't make a difference but I still don't slam the hood or doors shut when up on one corner.
It's easy to lift one corner on a C5.
Old Oct 13, 2011 | 03:57 PM
rboineau's Avatar
rboineau
If you can round up another puck and jack that will fit under the car it is a bit friendlier to the car to lift front and back on one side.
Old Oct 14, 2011 | 01:08 AM
Jistari's Avatar
Jistari
"Simple jacking question..."
On this forum (impossible)
Yes, one corner is fine. Pucks are a good idea but the pad on my low profile fits right into the cutout in the rocker panel so I dont use them (but its probably fine either way). Just remember hydrolic jacks are meant for lifting, not holding. Again, its probably fine but be aware (no head in the wheel well or under car unless jack stands).
Old Oct 14, 2011 | 08:55 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Good advice
Old Oct 14, 2011 | 06:22 PM
Trigger Creep's Avatar
Trigger Creep
It was true of C3 cars which flexed a lot. C5's were built much more rigid.
Old Oct 15, 2011 | 06:36 AM
baxsom's Avatar
baxsom
amen to that,
my 72 454 flexes like crazy. i always use drive up ramps or lifts when possible.
Old Oct 15, 2011 | 08:07 AM
eldudereno's Avatar
eldudereno
Or the whole front or back. Why put unnecessary strain on the chassis when you don't have to just with a little more effort
Old Oct 15, 2011 | 08:30 AM
CSM Z06's Avatar
CSM Z06
Originally Posted by cdkcorvette7
Old Oct 15, 2011 | 10:37 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I usually lift the whole side instead of a corner. Put pucks in their slots, , then jack between the two pucks at the cross member with a hockey puck . Then support car with jack stands or cut rail road ties, depending how high I need it. Cut rail road ties are great for tire, brake and fluid changes, not so critical for placement under the pucks. Go to the other side do the same and car is up off all fours in less than 5 minutes. If I want it higher do it in in several steps.
Old Oct 15, 2011 | 11:26 PM
yaknow's Avatar
yaknow
short answer, yes
Old Oct 16, 2011 | 01:41 PM
jayindy's Avatar
jayindy
....chuckle....
how true - wouldn't be the great place it is w/o CF members out there posting their thoughts.
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
― Terry Pratchett, Diggers
Old Oct 16, 2011 | 02:12 PM
garage-ghost's Avatar
garage-ghost
The only C3s I've seen flex enough to worry about body panels cracking are the ones with bad frames.
Old Oct 16, 2011 | 06:45 PM
When I detail my car, I lift the car at each corner to do the wheel well and wheel. You won't have any problem lifting the car the way you describe - just use the jacking pucks.
To Simple jacking question...
