Easy Drag Race Question A4
Old Oct 14, 2011 | 11:23 PM
GGEENN's Avatar
GGEENN
Default Easy Drag Race Question A4
Should i leave my vette in 3rd or Drive when drag racing, and how much RPM should i have it on to get a good launch?
Old Oct 14, 2011 | 11:27 PM
Aerovette's Avatar
Aerovette
If it were me, I'd have it in 1. But what do I know?
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I leave mine in "D" when I go to the track, It won't hit 4th, But that is where I leave it.
I power brake to about 1500 or so when I launch.
Old Oct 14, 2011 | 11:29 PM
GGEENN's Avatar
GGEENN
Thanks Bill, what are your times?
Old Oct 14, 2011 | 11:33 PM
Mr.Bill's Avatar
Mr.Bill
Keep in mind I am at 5000 feet in the summer heat of 90 plus.
I run a 13.8 and 103 I think it was.
Old Oct 15, 2011 | 12:53 AM
rebelheart's Avatar
rebelheart
I leave my car in D and bring the rpm only to 1000.I run 12.80's.Pretty much stock with 3.15's.Sea level and 90+ degrees.Took lots of practice though.I started at 13.16.
Old Oct 15, 2011 | 01:35 AM
GGEENN's Avatar
GGEENN
12.80's stock 3.15's thats REALLY good got any tips???
Old Oct 15, 2011 | 01:54 AM
209TIME!!!'s Avatar
209TIME!!!
put it in 3rd take it up to about 1500rpm and go for it!
Old Oct 15, 2011 | 08:27 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Leave it in 3. If you leave it in D you can shift to 4 if you have to lift.
Old Oct 15, 2011 | 09:35 AM
robert miller's Avatar
robert miller
Default ttt
All of you guys above are per say stock motors YES...
Old Oct 15, 2011 | 01:19 PM
rebelheart's Avatar
rebelheart
My internals are completely stock.Just a Corsa catback,Vararam (which dropped my ET 3/10,s) and a Predator tune.
Old Oct 15, 2011 | 01:21 PM
1quick1's Avatar
1quick1
with 3.42's would you do 3rd or D?
I need to get mine to the track but been wondering what I'd run with vararam, corse, 3.42's and tune.
Old Oct 15, 2011 | 01:52 PM
GGEENN's Avatar
GGEENN
Old Oct 15, 2011 | 07:19 PM
paint it black vette's Avatar
3.73 gears launch at 1800 rpm car runs 10.3 n/a 9.899 on a 100 shot . launch car in 3rd gear n/a run and cross stripe at 131.43 mph. drive with juice cross stripe at 137.57mph
Old Oct 15, 2011 | 08:47 PM
chaase's Avatar
chaase
St. Jude Donor '12
Put it in 3rd and slightly load the converter pre-launch. I had a lot of practice while stock and that worked out the best for me. I tried to load the converter more at times, but I would red-light and I did not notice a significant difference in times.
Old Oct 15, 2011 | 08:59 PM
robert miller
I say here alot of hard pulls in D with a set of good tires on the back and you are going to be getting a new trans befor long doing that. Better pull out in 3rd then hit D in it.... Robert
Old Oct 15, 2011 | 09:01 PM
chaase's Avatar
chaase
St. Jude Donor '12
You don't need to go into D for a 1/4 mile run even w/3.42s
To Easy Drag Race Question A4
Old Oct 15, 2011 | 09:03 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Leave it in 3rd, lower your rear tire pressure and add some air to the front ones. Put in competition mode and do a nice burn out to warm the rear tires up. Stage at the light and try and keep your foot on the brake and just give it enough throttle to keep from creping forward. When you see the last yellow light relies your foot from the brake and punch the gas pedal. If your tires hook you should be good to go.
Old Oct 15, 2011 | 09:20 PM
robert miller
I love my 3:42 rear set up with the c6 z06 chg over. But with the 3:73 or 4:10 gears you will in the 1/4 mile for sure...
Old Oct 16, 2011 | 11:43 AM
rebelheart's Avatar
rebelheart
I never go though the water nor do any burnout,just a short chirp before I stage.Power braking over 1000 rpm's has always hurt my ET.I think the computer senseses engine load with no rpm or speed gain and starts to retard timing.I dont fool with my tire pressures either,but I do use comp mode.
