Red Brake calipers ?
Old Oct 15, 2011 | 10:30 PM
killain's Avatar
killain
Oldtimer
Default Red Brake calipers ?
Another question, Anyone paint their calipers red? What kind of paint did you use and what was the process to the cleaning and prep work to applying the red hi-temp paint ? And how are your results ? How did the paint hold up ? Thank you !
Old Oct 15, 2011 | 11:20 PM
highpsi98's Avatar
highpsi98
I painted my calipers red on my 98 SS Camaro. I used high temp. Engine paint and then sprayed them with a high temp. Clear coat. I used a dremel with a wire wheel to strip the old paint off. Worked really goof but was time consuming. A media blaster would work great. Just make sure you have the important parts covered so media doesn't get where it shouldn't be. Essentially I stripped the calipers down to the metal, then wiped them down with rubbing alcohol, hung them sprayed a few coats until they looked good, sprayed two coats of clear and was done. The looked great. Had them that way three years before I sold the car. Never had any issues with the paint or calipers.
Old Oct 16, 2011 | 01:06 AM
lumpdady's Avatar
lumpdady
I painted my calipers a little over a year ago. Like highpsi98 said it takes a little time due to cleaning. I used brake cleaner and a wire brush. I bought the brush on paint from autozone, sorry the brand name escapes me, but I will come back and repost it for you. If you take the time it will come out great.
After i painted the caliper and before I clear coated. Clean up the rased Corvette lettering with a die grinder.
Old Oct 16, 2011 | 01:10 AM
Aerovette's Avatar
Aerovette
I used Purple Power undiluted (wear gloves) and a small brass brush to clean them. Let them soak (mine were disassembled completely...pistons and all). I rinsed them and used caliper cleaner before I painted them. I painted them with caliper paint. Interestingly, the two that are painted actually look better than the two that are powder coated.
Old Oct 16, 2011 | 02:26 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
I used the standard Duplicolor brake painting kit that you can find anywhere.
Cleaned good, and painted them on the car. I also painted the caliper mounting brackets. They came out looking good. It's not show quality, but looks good from a few feet away. For a better finish, I'd swap them out for powder coated units.
Just a tip. When the paint hasn't fully cured, take a razor and slice off the lettering. Gives you a clean look and not as difficult as trying to sandpaper it off.
Did mine 4 years ago and it's held up well.
Still, here's the results.
Old Oct 16, 2011 | 07:25 AM
killain's Avatar
killain
Oldtimer
Default Caliper Painting
Wow, you guys have done a fantastic job. And I'm sure the details are in the "prep-work" like any painting. But you folks have done fantastic and they still look great four years later. I see you have 'Drilled and Slotted', where did you purchase them ? Did you change the pads to ceramic or another dustless pad and from whom did you find them? Thank you !
Old Oct 16, 2011 | 08:54 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Pepboy's or any auto store has a Caliper Paint Kit you can get for $20 - comes with everything you need to do the job right!
Thanks,Matt
Old Oct 16, 2011 | 09:36 AM
lumpdady's Avatar
lumpdady
Thanks,Matt
Old Oct 16, 2011 | 10:18 AM
cal45's Avatar
cal45
As nj02vette posted, the Duplicolor Caliber paint kit works well. I just did mine a few weeks ago.
BEFORE
AFTER
Old Oct 16, 2011 | 11:54 AM
GBsC5Vert's Avatar
GBsC5Vert
From: LA/OC border, probably sittin' under the patio, by the pool...smokin' a cigar! SoCal
I had my calipers off the car, some leave calipers on car and mask off everything not to get sprayed. I found it easier to remove calipers. I was changing brake fluid anyways. Used sppedbleeders when I reinstalled every thing. Remember to clean, clean, and then clean some more! Brake cleaner, wire brush. Used a Dremel to clean up some casting marks, rough edges. Primered, then three coats of red. Caliper brackets were painted silver. I also baked in oven at 375, for 20 minutes or so. Don't laugh, I think it helps! lol. Removed paint from letters with razor blade, then polished letters with some 1500 W/D sand paper. Some clear the calipers, some don't...I didn't. Red looked good, and I thought I would be pushing my luck and get a run/sag if I cleared! Good luck!
Old Oct 16, 2011 | 12:06 PM
jrose7004's Avatar
jrose7004
I ued VHT in a rattle can from AutoZone. I painted them on the car. I did it about 3 years ago or so and they still look great!
Old Oct 16, 2011 | 08:15 PM
nj02vette's Avatar
nj02vette
I bought the drilled/slotted rotors from GMPartsHouse. (FYI, I also had them plated, since the hats will rust, so they still look good too!)
You have to remove the caliper mounting brackets to install the new rotors. While off I cleaned them good and painted with the Duplicolor spray that GBsC5vert posted. I left the calipers in the car, didn't disconnect them, and painted them with a brush using the duplicolor brush kit that every automotive store sells. So I did a combination of spraying the brackets, and brushing the calipers.
In any event, I'd definately paint the brackets since it makes the brakes look bigger, too.
Old Oct 16, 2011 | 08:57 PM
I've painted the calipers on my last two C5s red - used Folia Tec paint. The paint has held up very well - it is a two part epoxy based system.
To prep the calipers, I used a lot of brake cleaner to get any grease off and then some very fine steel wool, followed by more brake cleaner.
To Red Brake calipers ?
