[Z06] Is this Corvette a good deal?
Old Oct 21, 2011 | 06:54 PM
toyotabike's Avatar
toyotabike
Default Is this Corvette a good deal?
Here is the details:
2002 C5 Z06
electron blue
black interior
60k miles
3rd owner no accidents
vortech supercharged (not sure what kit but he claims it makes 480rwhp 6 psi)
lowered with lowering bolts (not sure what that is)
C6 Z06 wheels, but only 20% life left, some negative camber wear (are these cars easy to align properly?)
body i would rate it 7.5/10 (some light scratches here and there) and interior is 9/10
short shifter
CD player with navigation
skip shift eliminator
steering column lock recall done
stock valve springs unknown
some service records available
$22000
Old Oct 21, 2011 | 07:18 PM
Kmcoldcars's Avatar
Kmcoldcars
If you want a supercharged Z06 and the install was done properly it does not sound too bad. Lowered on lowering bolts just means longer bolts were installed to lower the car a little further than it could be lowered with the stock bolts. A stock alignment will give tire wear on the edge. A 4 wheel alignment that is not so aggressive will take care of the tire wear problem. Do you know if the bottom end, cam and valve springs, push rods, etc., and clutch were replaced with stronger ones to handle the extra power?
I have a relatively stock 2002 Z06 with long tube headers and Borla exhaust. At 30 MPH in second gear on dry pavement I can step on the gas and spin the rear tires. The extra power from a supercharger will not really do you any good until your speed is up quite a bit as the stock Z06 has more power than can be used at lower speeds on the street. For the track or drag strip it is another story.
Old Oct 21, 2011 | 07:31 PM
Grimlock's Avatar
Grimlock
Seems too high to me unless you really want a supercharger. The supercharger decreases the value of the car, not the other way around. I would try to get the car for under $20K, but I would do a solid inspection on the engine and make sure you know the details on what they did (proper documentation!) If you goal is to find a Z06 with a supercharger, then I might pay more. You obviously couldn't buy a stock Z06 and modify it to this level for this price.
Old Oct 21, 2011 | 07:32 PM
toyotabike's Avatar
toyotabike
No, the engine internals is completely stock. The clutch is original still.
It also has the borla exhaust on it which seems to be fairly common.
Old Oct 21, 2011 | 07:36 PM
toyotabike's Avatar
toyotabike
Thanks for the info. I never knew a supercharger will decrease its value. I thought that it would make the car more desirable.
Old Oct 21, 2011 | 07:53 PM
Grimlock's Avatar
Grimlock
No, it scares away most potential buyers. You have to assume the car was driven hard, and you have no idea how well it was maintained. If I were buying a supercharged car, I would want to have a $5K buffer in the bank for the first 6 months or so just in case something major goes wrong. I would also do a very detailed inspection done by someone who is an expert on supercharged LS engines.
Old Oct 22, 2011 | 06:10 AM
Xx_Black-out's Avatar
Xx_Black-out
St. Jude Donor '08-'11-'12
Do you know how many miles have been put on the car with the blower?
You mentioned service records... Try to get every bit of info you can about the car, reciepts, call the local dealerships to see if they have any records matching his VIN. Even run a CarFax if you haven't yet. All this can help you make your decision on the car and it can be a big help with the resale down the road!
Old Oct 22, 2011 | 10:47 AM
madmatster's Avatar
madmatster
St. Jude Donor '10
.... Is it just me or does 480whp seem low. Even assuming everything else is stock... That's got to be a very very modest tune.
I'd make sure I had money for a clutch. Also knowing how many boosted miles were on the car would be key.
Good luck.
Old Oct 23, 2011 | 03:11 AM
toyotabike's Avatar
toyotabike
I am going to pass on this car. After talking to him in person for 5 mins I can tell he is a complete idiot. I asked him "so has the major services been done yet on this car. Items like plugs, wires, belts, etc...". He answers "yes the TIMING BELT and everything has been changed already. I take really good care of this car and it is a 600hp beast".
In my head, okay your an idiot and your car is way over rated.
Old Oct 23, 2011 | 04:43 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
2002 C5 Z06
electron blue
black interior
60k miles
short shifter
$22000
The asking price is very high.
http://www.edmunds.com/chevrolet/cor...e-results.html
To Is this Corvette a good deal?
