backup onto ramps
Old Oct 22, 2011 | 01:21 PM
chasboy's Avatar
chasboy
Oldtimer
Default backup onto ramps
I just picked up some Rhino ramps on sale. I was wondering if it's possible to backup onto them to get enough clearance to install the CAGS eliminator. I figure the front spoiler will touch, I wouldn't go any higher. I could add some 2x10's for the front wheels to climb up on too.
Old Oct 22, 2011 | 02:16 PM
m6 c5's Avatar
m6 c5
I backed up onto the race ramps I have and it worked great. I dont think I needed to get the front any higher but it wouldnt hurt.
Old Oct 22, 2011 | 02:30 PM
chasboy's Avatar
chasboy
Oldtimer
I was thinking a couple of 2x10 'steps' in front would allow it to pivot without damage.
Fred@ReverseLogic's Avatar
0Fred@ReverseLogic
Former Vendor
Measure the length of the overhang from the front axle. Divide that number by the wheelbase. Multiply the result by the height the rear tires will be off the ground. That will be the amount of ground clearance you lose under the front of the car with the rear tires on the ramps. The calculation should look something like this:
35/105 x 6 = ~2
Your mileage will vary if you are not on completely level ground.
Old Oct 22, 2011 | 02:34 PM
m6 c5's Avatar
m6 c5
I didnt need anything to keep the front from bottoming out just using ramps. Now when I changed the exhaust out I had to get the front end about 6 inches off the ground.
Old Oct 22, 2011 | 02:38 PM
jrprich's Avatar
jrprich
YES you can easily back up on them, I do it all the time. You can also drive right up them in the front without and wood blocks.
Old Oct 22, 2011 | 03:45 PM
Jet-Jock's Avatar
Jet-Jock
Generally the low profile race ramps or those with pre loaders it's a piece of cake. That's how I installed my CAGS. That way its' free and clear in the area you need to work.
Old Oct 22, 2011 | 03:51 PM
Kale's Avatar
Kale
Tons of space, unless you're morbidly obese.
Old Oct 23, 2011 | 12:50 AM
You should have enough clearance to slide under the driver's side and install the CAGS eliminator. I always used a floor jack with some jack stands to get extra clearance though.
Old Oct 23, 2011 | 07:20 AM
chasboy's Avatar
chasboy
Oldtimer
Seems great. The skip shift started to **** me off yesterday!
BTW, there was a thread, which I cannot find, about jacking the rear of the car from one point, under the rear spring? I remember a lot of controversy regarding that, and just wanted to be clear.
Old Oct 23, 2011 | 01:25 PM
Dope's Avatar
Dope
Resident moron
You can jack the car from the rear subframe no problem. I have been doing it for about a decade. Just go right between the exhaust tips and use a piece of wood to spread out the load on the rear subframe (bridge the gap so to speak).
Be sure to chock the front tires when you do this, since the car can roll once the rear tires leave the ground (if you're on any sort of uneven ground). Use jackstands too, obviously.
Dope
Old Oct 23, 2011 | 01:38 PM
Jet-Jock's Avatar
Jet-Jock
Sticky at top of C5 General has some thoughts on jacking:
wood alternatives:
sticky link
Ready made options scroll down to LTZ06's post.
There's another one to similar to the "ready made option" but uses a 2"x6"x16" piece of lumber. I do this, but it's a treated piece of lumber. And a low-profile race jack from harbor freight.
Old Oct 23, 2011 | 03:39 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
35/105 x 6 = ~2
Fred, good to know...but I think you went straight over their heads with this one! BTW, still love my raceramps with my 4 poster.
Jerry
Old Oct 23, 2011 | 04:21 PM
chasboy's Avatar
chasboy
Oldtimer
Job done. Backed up real easy, nice height. BOY is that car clean underneath!
*Forgot to mention, the Rhino's have a rubber 'foot' near the end of the wedge to prevent sliding.
To backup onto ramps
