Head Lite Door won't Need Fourm Help
Old Oct 27, 2011 | 10:47 AM
Button's Avatar
Button
Default Head Lite Door won't Need Fourm Help
How hard is it to replace the Plastic Gear which I hear is
a weak point in the C5.. Where can I buy this with out going
to the dealership which I hate to do for anything !! ??
Thanks in advance for any help ????
Old Oct 27, 2011 | 10:58 AM
DannyM's Avatar
DannyM
Replace it with a brass gear and you'll never have to do it again. I got mine from Corvette Central. Took me less than an hour to replace one. There is a good tutorial on here somewhere, use the search function to find it.
Old Oct 27, 2011 | 11:07 AM
cdkcorvette7's Avatar
cdkcorvette7
http://forums.corvetteforum.com/1561976074-post2.html
Old Oct 27, 2011 | 11:10 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Its very easy... there are several ways to get it out depending on how small your hands are...
Replace it with a brass gear. I would do both sides so you dont have to do it again in 6 months when the other side goes out.
Let the epoxy dry over night before replacing.
Old Oct 27, 2011 | 11:56 AM
Button's Avatar
Button
Default IcuLuKn C5 Question ??
Where and why did you use epoxy ?
Old Oct 27, 2011 | 12:10 PM
cdkcorvette7
The earlier models use bolts for the case that the gear is in the later models are sealed. If you have a later model C5 you'll have to break the seal and use epoxy to seal it back up when you're done...
What year is your car?
Old Oct 27, 2011 | 12:45 PM
guido7834's Avatar
guido7834
http://forums.corvetteforum.com/c5-t...placement.html
This is what I used
Old Oct 27, 2011 | 12:50 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Would the older model gears (bolts) work with the later years, i.e. 2003 and 2004? Are they still available? It would be nice to get the older casing, remove the plastic gear and then install the brass gear without cracking the casing open like a lobster shell.
Old Oct 27, 2011 | 01:13 PM
cdkcorvette7
No idea if they're compatible; I've never compared the two. I seriously doubt if the older variants are still available from GM.
It's really not a big deal to open the case up though... I've done a few times with no issues...
Old Oct 27, 2011 | 01:30 PM
Button's Avatar
Button
Default H/L Gear
Mine is a 2000..... ??
Old Oct 27, 2011 | 01:40 PM
cdkcorvette7
Pretty sure 2000+ units are sealed not bolted (someone correct me if I'm wrong). It's really not a big deal though... You headlight kit should include some new epoxy to use along with instructions.
Old Oct 27, 2011 | 01:54 PM
mfile2000's Avatar
mfile2000
Default Funny you should ask
I have my passenger side assembly out right now. I tried the quick easy fix but it wasn't so easy and it certainly wasn't quick for me. Then Monday night I took the whole assembly out, brought it into the study, took my time, replaced the gear, put on the urethane (no longer epoxy), clamped it up and am waiting for it to cure all week. I also ordered a bracket to make sure the cover over the gear doesn't come out. Nice and slow, from rounding up the tools to putting the final clamps on took me about 1.5 hours. I am not doing the other side until it fails because doing now doesn't save me anything. Also, I believe my gear failed due to loose tabs holding the motor in place. The other side is nice and tight.
I plan on putting it back in this weekend.
Good luck.
Old Oct 27, 2011 | 02:45 PM
oh1vette's Avatar
oh1vette
My 2001s were sealed...
Old Oct 27, 2011 | 03:25 PM
Dave68's Avatar
Dave68
I believe some of the late model 2000s have the epoxied covers. I hope to replace both sides very soon, as I have the kit.
Patches wrote a great procedure for doing this.
Old Oct 27, 2011 | 04:01 PM
guido7834's Avatar
guido7834
Good luck.
I believe you are correct about the tabs holding the motor being loose. I had the same problem with mine. Or I thought the terrible grinding the motor made when the gear failed, caused the tabs to work loose? Either way, one is replaced and both motors are nice and tight now.
Also, it wasn't necessary to remove the whole headlight assembly. I just removed the motor.
Old Oct 27, 2011 | 08:39 PM
bj454ss's Avatar
bj454ss
My 2000 has the cover sealed not bolted.
Old Oct 27, 2011 | 08:41 PM
bj454ss's Avatar
bj454ss
Good luck.
Where did you order the bracket for the cover from?
To Head Lite Door won't Need Fourm Help
Old Oct 28, 2011 | 07:39 AM
guido7834's Avatar
guido7834
I got my replacement gear with the brace here:
http://www.top-downsolutions.com/hea...tte-p-128.html
Old Oct 28, 2011 | 11:39 AM
mfile2000's Avatar
mfile2000
http://rodneydickman.com/catalog/ind...1237d149546ecf
Old Oct 28, 2011 | 11:46 AM
mfile2000's Avatar
mfile2000
I know, however at first I tried the quick easy fix which called for removing just the motor and rotating the gear 180 degrees. Well, it didnt' work, I dropped a nut into the cavity and had hell of time getting the arm back on the shaft. Also, I would have had to unplug the lights to take it to a bench and I didn't want to do that.
To put in the permanent fix, I found it much more comfortable to remove the headlight cover and the hood support, then easily turnoff the 6 nuts and remove the entire assembly and then lay it out in the study, take my time while referencing the procedure on the computer to make sure I didn't screw it up. I had an "oh crap" and then figured out the drivers side shaft goes in the opposite direction from the passengers side.
