[Z06] When inspecting a C5 Z06....
Any input would be appreciated.
Goodpoint above about checking for leaks but I also doubt many guys are going to be ok spraying down their cars for you.
I recently bought one with 40K miles, and mine has been far from trouble free. In 3 months I have well over $4K into the car, though about $2K of that was expected maintenance. EBCM failed with a damaged connector, water pump failed, needed all new belts, replaced valve springs, etc. The EBMC connector requires pins that are no longer made. So it required that I buy a whole new harness out of a totaled car! On top of that I replaced all the fluids, got new tires, aligned the car, added a steering lockout removal module, iPod adapter, etc. I think my car is going to need a new clutch very soon too. I don't the prior owner replaced the clutch fluid ever. I am now bleeding it once ever tank of gas and it is still slightly sticky. http://www.rangeracceleration.com/Clutch_Care.html So I am guessing that will be another $2K in the next few months. And believe it or not I had this car checked out by one of the top Vette guys in my area, and he missed all this!
Unfortunately, my car seems to have been an almost worse case scenario, and I checked everything out before I got it. So hopefully you are luckier than me!!!
Someone also put colored letters in the dash on on the rear where it says "Corvette" ... that's not stock either.
Nice looking Zee!
Nice looking Zee!
Not that it matters too much, but, how could I tell if the wheels were chromed OEMs or aftermarket?
