Hazard Switch Removal
Old Oct 30, 2011 | 09:41 AM
VETSTYL's Avatar
VETSTYL
Default Hazard Switch Removal
I need to remove the hazard switch and I can't find the posting that shows the easy way. The easy way - not having to remove the friggin dashboard
Old Oct 30, 2011 | 09:48 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I was having issues with my hazards and turn signals working and not working, I fixed mine the easy way, I installed the Hyper flash digital relay and it took care of my issues, I bought it from JWMotoring forum vendor. It installs under the dash on the drivers side. Very easy.
Mr.Bill
http://shop.jwmotoring.com/product.s...2&categoryId=4
Old Oct 30, 2011 | 02:26 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Yep I did the same.
It came in handy since I went ahead and installed some LED tails and front corners.
No hyperflash and turn signals work every time.
Old Oct 30, 2011 | 03:04 PM
rpm462's Avatar
rpm462
Just did mine about 8 months ago, wasn't that bad. Try this...
http://www.kd5fx.com/HSwitch/HSwitch.htm
Oh, I have the hyper flash relay installed as well but still had problems when hazard switch went bad.
Here's another link that might help.
http://forums.corvetteforum.com/1553424533-post12.html
Old Oct 30, 2011 | 08:38 PM
lwd2000's Avatar
lwd2000
http://api.viglink.com/api/click?for...13200214357693
this is the link I used, worked great. The "tricky" part was getting the new switch back in.....tricky but doable.
Old Oct 30, 2011 | 09:36 PM
Thanks for the links - saved this for possible future use.
Old Oct 30, 2011 | 10:08 PM
Baldfart's Avatar
Baldfart
Mr.Bill
Just put one in last weekend to fix turn signal issues. Works great!!!
Old Oct 30, 2011 | 10:21 PM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
Dash comes out pretty easy. Not as hard as you think.. Just replace the switch and be done with it.
Old Oct 30, 2011 | 11:33 PM
FourG63 97GST's Avatar
FourG63 97GST
I had luck getting it from the under the radio too.
To Hazard Switch Removal
