Battery
Old Nov 4, 2011 | 06:42 AM
barblarry93's Avatar
barblarry93
Default Battery
Is it OK to remove battery from car for the winter months?
Old Nov 4, 2011 | 08:40 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Sure is OK but not recomended , why can't you just put a trickle charger on it ,
Old Nov 4, 2011 | 08:49 AM
4 KRUSIN's Avatar
4 KRUSIN
I used to take mine out. You have to reprogram your radio with the security code and fobs, but its no big deal. That said, invest in a float charger. I use the smallest Battery Tender (about $30) and leave the battery connected in the car. Much easier and better for the battery and car.
Old Nov 4, 2011 | 10:07 AM
You can do it, but not really necessary. I hook mine to a Battery Tender Plus and its good for all winter.
Old Nov 4, 2011 | 10:12 AM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
how do you reprogram radio? i also removed my battery
Old Nov 4, 2011 | 10:34 AM
jrose7004's Avatar
jrose7004
I wouldn't.
Old Nov 4, 2011 | 10:47 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Hope you didn't have the security turned on the radio, If so I hope you wrote down the access code. It is a pain to get your radio to work again.
Old Nov 4, 2011 | 11:15 AM
02HREBlue's Avatar
02HREBlue
I agree battery tender or CTEK etc.is best option and that is what I use BUT.........I just had to start storing my car at a facility WITHOUT electricity(very common situation), and thus battery removal is the ONLY option. I still put the removed battery on a tender in the garage.
Dont quite understand previous poster saying it is not good for the car? IMHO nonsense.
Old Nov 5, 2011 | 10:51 AM
corvettemods1's Avatar
0corvettemods1
Former Vendor
easier to install a trickle charger
Old Nov 5, 2011 | 11:22 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Yes. You quite definitely want to remove a battery from a car in cold storage where there is no electricity.
Take it home and put it on a desulfating trickle charger, and monitor the acid level at least every few weeks. Use distilled water.
Keep the battery tray area completely clean. Use a battery acid cleaner like this:
to make sure there is no hidden acid lying around.
Old Nov 5, 2011 | 02:06 PM
robert miller's Avatar
robert miller
Old Nov 5, 2011 | 04:37 PM
dquagliaroli's Avatar
dquagliaroli
Old Nov 6, 2011 | 08:11 AM
Chuck A's Avatar
Chuck A
how would i know if the security is on? i never heard of this
Old Nov 6, 2011 | 09:56 AM
Mr.Bill's Avatar
Mr.Bill
You will have a red light on the radio that blinks when the key is off.
Old Nov 6, 2011 | 02:57 PM
Chuck A's Avatar
Chuck A
crap, i dont think i seen that and hopefully it wasnt in security mode, but i never looked, all i ever seen was the vert saying security on the dash when i would put the key in, hopefully i will be OK, what needs to happen if this happened?
Old Nov 6, 2011 | 03:01 PM
Mr.Bill's Avatar
Mr.Bill
I have a file that tells you what to do if the radio is locked. Let me know.
Bill
Old Nov 6, 2011 | 04:17 PM
PMPNSEZ's Avatar
PMPNSEZ
Bill
Ahhh the beauty of the CF. If you have a problem there's someone here that knows how to fix it. Hopefully the radio was not in security mode
To Battery
Old Nov 7, 2011 | 09:27 AM
Chuck A's Avatar
Chuck A
Bill
thanks, hopefully i wont be bothering you about it, it will be a few months before i check it, thanks again
Old Nov 7, 2011 | 10:31 AM
pluslt's Avatar
pluslt
I take mine out for the winter. I had one bad experience with a trickle charger and it soured me so I don't use them.
Old Nov 7, 2011 | 05:19 PM
Jims2001's Avatar
Jims2001
I have been taking mine out every winter since 2004 never had a problem or had to reprogram anything.
