I've got tons of old school knowledge, but have never messed with tuners and the like. I have a stock 02 6 speed. I installed LT's and a no cats X-pipe. Questions - 1) should I have my car tuned by a tuner/dyno? 2) should I tune it myself with a Diablo or HP, if so, which one? 3) should I buy a mail tune? Any and all help will be appreciated.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
All 3 will work, Tuner/Dyno being the best, That will get you the most HP. I am not a fan of the hand held tuners, Mail order will work, That is what I did, I had Chuck CoW do me a mail tune and it has been great for 2 plus years now.
Mr.Bill
I'm very old school myself, back then I was one of guys that would get into the carbs. Way past changing MJ's & adjusting low speed mixture screws. I drilled throttle blades, modified air bleeds, secondary opening, rate of opening. Re worked advance curves, limited travel so you could run more intial....re plumbed the vacuum advance.........the good old days
Now I get to do all of that & much more from the comfort of which which ever chair I want to seat in
You don't need a dyno, most tuning is idle, starting & drive-ability. The WOT stuff can be done on some back roads, even better if there are some nice grades. If you are not able to find that a few WOT pulls on the dyno.
The most difficult part for me was learning my way around the software, that is on going & never ending. The software packages are very reasonably priced with much needed scanning & logging.
Mr.Bill
Originally Posted by 8VETTE7
If you don't have knowledge of the air/fuel, timing, etc tables in the PCM, (old school knowledge indicates that) I would leave the tuning to the pro's. No personal offense intended.
I'd do either the mail-order tune (Chuck at COW is good or ECS I think does it) or find a good shop locally with a dyno and have them do it.
Thank you all very much for your advice. I really appreciate it. Mr. Bill - you look like Frank Zappa.
Lots of people put faith in DYNO tunes, but for a car like yours....WHY?
People have said to me..." Chuck, you like to street tune... How do you know how much power I made...???"
My answer is that first off...It's REAL LIFE - NOTHING IS MORE REAL than ME DRIVING YOUR CAR. Period.
My question to the Dyno Guys....When you take the car off the dyno (simulation of real driving) what's your guarantee
that the power you made on the dyno is STILL BEING MADE after it's off the machine????
The load is different, the wind resistance is different, the cooling of
the engine and drivetrain is different, and the air jamming into your
cold air intake is TOTALLY DIFFERENT...
How could it be THE SAME..???
I'll tell you what.... IT ISN'T.
While I bought a really nice dyno, and YES, they have their place.
Your average bolt on car does not benefit much if at all from DYNO TUNING.
In fact, I'll argue.....If not GUARANTEE, a properly done STREET TUNE....
A little back ground here, do you have to smog it every 2 years?? if so, if you tune it for performance, you need to be able to return to the stock setting for that, in that case the hand held has a default I hear. Or it can get expensive bringing her in to down tune her for a smog.. I come from Commifornia so those are my issues, thus I leave well enough alone.. Good luck.
Here we have to smog every year, I have never failed with my tune.
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
You would be a perfect fit for our mail order tune special, here is a link for you to review.
Your not the only vendor Chuck, we just do not have the time with a very busy shop schedule of tuning to promote that end of tuning as much as you do, so we sell them when appropriate.
Maybe not the only vendor that sells the Autocal...but I don't think that's the statement that was made. It said they are possibly the only vendor that 'supports' the Autocal.
And from my experience that seems to be true. I purchased the Autocal & email tunes from another vendor and ended up having some problems. Over 2 months and many emails later I still do not have the problem resolved.
Not knowing what else to do I did a little research and came across Chuck's name. I messaged Chuck to see if he could offer any assistance or insight. Even though he didn't sell me the Autocal or provide the tunes, I got a response in less than an hour.
To me, if you're going to sell a product, no matter what quantity, you should be prepared to support it.
Go with a COW Tune. It is the best money spent so far. His mail order tunes are super easy to use and Chuck will get it done correctly. I have heard horror stories from other so called mail order tunes. Look around the forum I think you will see that Chuck has a great rep. He has done two tunes for me on my 08 and current 11. no issues at all top notch
Is always BETTER.
Chuck CoW
I'd have to say your mail order tune works quite well, Chuck! Thanks again!
With standard bolt ons like you have, a mail tune will work perfectly. No need to spend a ton of money on a dyno tune unless you have a ton of mods like a big/head cam combo or F/I
Chuck does ALL my tuning. I am EXTREMLY HAPPY with the performance and fuel efficiency improvements that he made on my cars!! You wont be disappointed!! I know I wasnt!!!!
