Ash tray door question
Old Nov 8, 2011 | 02:56 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by wally2004
Great look! Where did you get the kit for seat heater? I really like the way the switches look on this set up.
Got it at PFYC. Give them a call and they'll get you hooked up. Just FYI; you'll have to trim the A/H circuit board if you want the switches where I have mine. If you decide to do this shoot me a PM and I'll find the template I made and send it to you.
Old Nov 8, 2011 | 06:47 PM
m6 c5's Avatar
m6 c5
Originally Posted by srs244
i believe the rational (if that word can ever apply to anything at the general) is that it will keep any ashes (for those that actually use it as an ashtray) in the receptacle, figuring that the outer door isn't going to make any kind of a seal for anything in the ashtray. sooner or later if you haven't experienced it yet, the spring loaded inner door will force the outer door to remain ever so slightly "open" and if you care, it is annoying.
My outer door was doing the same as yours and not shutting all the way and I figured it was just because it was old until I went to change out my shifter and I noticed that yes there was a fair amount of wear on the hole where the spring mounts but all I had to do was put the spring back like it was supposed to and it stays shut now. I figured it would just pop right back off but it is still working and its been like that for several months now. So if you ever have your dash apart then its worth a try, you could make the hole smaller again using some epoxy if you wanted to do that too.
