Difficult shifting 6-speed fixed
Old Nov 17, 2011 | 02:51 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by ZeeOSix
OK ... I just got off the phone with Tremec Tech Dept (talked to Rob). Tired of non-concurring info on this.
Tremec Tech Dept said:
1) ALL GM vehicles with at T-56 transmission started using the carbon blocker rings in the 2002 model year. He said GM had to approve the design, and therefore the 2002 model year is when the carbon rings made it into production for ALL GM vehicles. So, the info in the link I references saying F-body T-56s started using carbon blocker rings in 1998 is false.
2) He said that Tremec has tested various synthetic transmission oils for compatibility with the T-56. He said that Mobil 1 Full Synthetic AFT IS recommend even for the T-56 transmissions with the paper blocker rings. They DO NOT recommend Royal Purple or Redlline because of additives that they use that are not in Mobil 1. He didn't give me a whole list of non-approved fluids, only the RP and RL ... there could be others. But bottom line is Tremec says Mobil 1 ATF has been tested to be comparable with the paper blockers.
This is info directly from the Tremec Tech Dept ... don't shoot the messenger.
PS - cdkcorvette7, looks like there's still a slight discrepancy on if the carbon rings started with 2001 or 2002 model year Vettes ... but I was just told that ALL GM vehicles with T-56 transmissions started using the carbon rings in the 2002 model year.
looks like we're never going to get an answer that all the "experts" agree on. When I called tremec they told me it was 01+... I know for a fact my 01 has carbon rings in it because it was just torn down and rebuilt by a forum vendor a few weeks ago and I watched it.
Old Nov 17, 2011 | 03:49 PM
ZeeOSix's Avatar
ZeeOSix
Like going to see 5 different doctors ... you'll get 2 or 3 different answers.
Who knows ... maybe some late built model year 2001 Vettes got carbon blockers - what's the month/year built info on the door sticker?
In any case, Tremec Tech said you can use Mobil 1 full synthetic ATF in any of them, regardless if they have paper or carbon blockers. I asked if Tremec actually did extensive testing with Mobil 1 synthetic ATF on T-56s with paper blockers for compatibility, and he said "yes".
Old Nov 18, 2011 | 09:45 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Well, I know all too well what Mobil1 did to my BW transmission. No offense meant to Mobil1 as its a good product. Tremec transmissions are probably a bit different than the BW transmissions in whatever ways.
Old Nov 18, 2011 | 10:17 AM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Ok quick question... I have a 99 6speed with 45kmi, I want to change the fluid what should I use?
Old Nov 18, 2011 | 11:01 AM
cdkcorvette7
You have paper blockers so, if it were my car, I would use Dexron VI. (Dexron III isn't made anymore).
Old Nov 18, 2011 | 01:23 PM
Jet-Jock's Avatar
Jet-Jock
Think I'll look into this for my '01 which has 68K now. I have changed the differential fluid but haven't done the trans fluid. This may just improve it some. Thanks for the reminder.
BTW shifting not so much the issue for me and its very helpful to change your clutch fluid regularly, but I'm looking to see if the fluid change will smooth out the transmission some.
Old Nov 18, 2011 | 01:33 PM
Jet-Jock's Avatar
Jet-Jock
They don't make "DEXRON-III Automatic Transmission Fluid" any more?
I pulled that kind from the owners manual.
Old Nov 18, 2011 | 03:24 PM
cdkcorvette7
http://forums.corvetteforum.com/c5-t...ii-and-vi.html
Eric is a GM engineer. I didn't know until recently either.
Old Nov 18, 2011 | 04:29 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
I put RP in my '99 manual, when it had 60k on the clock. It now has 120k or so, and no real problems. The shifting improved alot with an MGW install, and it never really has gotten worse. It is hard to get into gear sometimes, but it isn't really a problem.
Old Nov 19, 2011 | 01:37 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Unless it's just my imagination shifting doesn't seem to be as "smooth" now then when I got my car 5 months ago especially into 1st. I really baby my car too. The previous owner installed a short throw shifter and several other mods so who knows of he ever changed the fluid and with what. If the fluid is new does mobil 1 smooth shifts out as opposed to regular ATF?
Old Nov 19, 2011 | 02:26 PM
Jet-Jock's Avatar
Jet-Jock
Since you are dealing with unknowns, one option is just to change the fluid and then you know what is in there and are starting from 0 on this fluid.
Old Nov 19, 2011 | 03:19 PM
Endeka's Avatar
Endeka
When you change the tranny fluid, do you need to have the shop tear it apart and change everything out, or is it a simple drain-n-fill like the differential?
Old Nov 19, 2011 | 03:24 PM
  #33
Jet-Jock's Avatar
Jet-Jock
Just drain and fill. You'll need to get it up high and level and a pump to refill.
Old Nov 21, 2011 | 04:40 AM
  #34
LIGHTNING's Avatar
LIGHTNING
DO NOT use Dexron VI in Tremec trans!
Use GM Manual Trans Fluid.
Originally GM published a tech sheet saying Dexron VI was back compatible for all Dexron III requirements, but then came out with an addendum that it's not to be used in manual transmissions.
Old Nov 21, 2011 | 09:31 AM
  #35
68ragtop69's Avatar
68ragtop69
MD Events Coordinator
2015 C3 of Year Finalist
Cruise-In X Veteran
CI-X Car Show Winner
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I had my Z06 out this weekend and noticed it was shifting a little rough...confirmed the fluid is a bit dirty, so I'll be changing mine out...going with Mobil-1!!
Old Nov 21, 2011 | 12:32 PM
  #36
cdkcorvette7
Didn't know that... You don't happen to have a link to the addendum do you?
Old Nov 21, 2011 | 12:41 PM
  #37
LIGHTNING's Avatar
LIGHTNING
http://gmspecialservicetools.spx.com...cs/may2007.pdf
To Difficult shifting 6-speed fixed
Old Nov 21, 2011 | 01:34 PM
  #38
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
I know this has been beat to death, but the resident expert in my book is Bill Curlee, and just like the old EF Hutton commercials say, when Bill speaks, people listen and Bill says that he likes Amsoil and that it will not harm the paper in the older transmissions. Just more fuel for discussion! Zuti
Old Nov 21, 2011 | 05:08 PM
  #39
foothills's Avatar
foothills
DAM
Just changed mine yesterday and put Dexron VI in it!
Old Nov 21, 2011 | 09:42 PM
  #40
LIGHTNING's Avatar
LIGHTNING
Originally Posted by foothills
DAM
Did the same thing. I switched it out as soon as I found out. Fortunately mine is a 2004, so I guess it wouldn't have made a difference anyway. If it's any consolation, I checked with a high-volume Corvette Chevy dealer tech, & he uses DexVI in all C5's.....told me he never even heard of the addendum!
