checked out a c5 tonight and....
Old Nov 8, 2011 | 10:25 PM
michael c. volpe's Avatar
michael c. volpe
Default checked out a c5 tonight and....
have a couple of questions (surprise surprise)
'service traction control' and 'service abs' showed up. traction control could have been 'active handling'. not sure now.
i know what they are, just not how big a deal it is to fix. could it be a fuse, short, serious issue?
car is a 2000 coupe. rattled a bit, kinda like my 82 with the t tops on did. car drove ok. did not seem as tight as i would have thought, although i may test it again later.
will bring it to my friend who has his own shop to look at better. interior was ok.
checked it out pretty quick, will get the carfax later, but everything seemed ok at first look.
car was an auto, black on black. was asking 10,500. 80k miles.
any answere to my questions would be appreciatted, as would any input.
thanks
Old Nov 8, 2011 | 10:27 PM
Jay_Rich's Avatar
Jay_Rich
I had that pop up on my 2000 once when I took a corner hard and the TC was on. Went away right away tho.
My car is very tight, Look into ball joints etc bc lowers are pretty pricey.
Jay
Old Nov 8, 2011 | 10:33 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
My 2002 showed these warnings recently and there are easy fixes and hard fixes depending upon the ultimate problem. I noticed these show up if I start it with my foot on the brake (6 spd trans). Otherwise it went away after running the codes. No codes indicated a problem.
Rather than use the forum search, you'll do better to google the message and you'll find good information....some from here, and some from other forums.
So, it would be a gamble....might be dirty connections, might be the cars abs or something serious is faulty.
So...it may...or may not...be a deal killer. Run the codes first if you can and that will help.
Good luck.
Old Nov 8, 2011 | 10:59 PM
2003 electronblue's Avatar
2003 electronblue
i had mine replaced at the dealership at a cost of one thousand dollars $750 for the modulue and rest labor and tax. but if u can do it yourself u can buy a used one on ebay for a few hundred then u must know how to not only install it but do all the codes..
Old Nov 8, 2011 | 11:06 PM
m6 c5's Avatar
m6 c5
Like others have said it can be as simple as a dirty connection which is a free fix all the way up to a deal breaker.
Old Nov 8, 2011 | 11:13 PM
Oh 2 Fun's Avatar
Oh 2 Fun
You had exactly WHAT replaced? Which "module" specifically?
Not to be rude....just would be nice to know the details of your expense and ultimate fix.....
Old Nov 9, 2011 | 12:07 AM
Triton4C's Avatar
Triton4C
Just so you guys know if you have an ABS module failure, it takes about 30 minutes to take it out. Then you go onto absfixer.com and pay 150 bucks and send your module out, he fixes it and then sends it right back out. You can continue to drive your car with the module out since it's just the electronic module you are taking out and not the whole pump assembly. SAVE a ton of money by doing it this way!
Old Nov 9, 2011 | 05:54 AM
Turbopower87's Avatar
Turbopower87
Did the car have aftermarket rims? If the staggered tire diameters are not matched properly this can cause these codes to be shown as well.
Why is the car so cheap? I would think he would be asking over $15k unless he knew there were problems with the car.
Old Nov 9, 2011 | 06:18 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
ABSfixer or anyone else cannot fix the EBCM on a 2000 model, only 2001-2004.
More than likely the EBCM module is shot and will need replaced. That can prove pricey for a 2000 since they are expensive if found used , and even more expensive new. (Anywhere between $750.00- $1500.00)
That could also explain why the car car does not feel as tight as it should.
I would have the car checked thoroughly. The price is too cheap, it sounds like the owner is trying to dump it.
Old Nov 9, 2011 | 08:38 AM
oh1vette's Avatar
oh1vette
thanks
Wow, my 01 coupe rattles NOTHING like my 77
Old Nov 9, 2011 | 08:56 AM
retired08's Avatar
retired08
Default Don't "jump the gun."
Like some of he other forum guy's said... 1. that sounds way too cheap, 2. codes showing up "sometimes" can be reset without further problems however, unless your a good wrench and can do the work yourself, I'd not take the chance. 3. There are too many good buys out there, especially from other forum members. Keep looking and good luck!
Old Nov 9, 2011 | 09:27 AM
fendermender's Avatar
fendermender
Funny that even with thread upon thread about this issue the EBCM difference still gets confused by so many.
And from what I have read, new ones for 97-2000 are discontinued and not available at ANY PRICE.
BTW, the car can still be driven with the system disabled just like a normal car. You would have to ask yourself if the cheap price is worth doing without. This is assuming it actually has an EBCM problem.
Old Nov 9, 2011 | 01:23 PM
TorchRedRocket's Avatar
TorchRedRocket
Zero rattles here on my 73k mile '01. Was the car wrecked? The car seems wayyy too cheap, and with the TCS/AH issues possibly being a bad EBCM (which is extremely hard to find for '97-'00), I would run away from this deal.
Old Nov 9, 2011 | 05:00 PM
Alex1's Avatar
Alex1
Kinda my thought also. Did you ask him about what he knew about the problem and repair cost?
Old Nov 9, 2011 | 10:43 PM
michael c. volpe
think they were stock rims.
am gonna check it our in the daylight tomorrow.
Old Nov 9, 2011 | 10:44 PM
michael c. volpe
a good friend of mine owns a shop down the street from me.
wouldn't think about buying anything used unless he gave it his blessing.
Old Nov 9, 2011 | 10:45 PM
michael c. volpe
rattled in terms of the targa top.
should have been more clearer.
To checked out a c5 tonight and....
Old Nov 9, 2011 | 10:47 PM
michael c. volpe
car is from a dealer. one town away.
right now that price is my budget (although i don't have to get one now)
and if it needs a lot of work, or has other issues, i won't walk away i'd run.
thanks for everyones input and help.
Old Nov 9, 2011 | 11:05 PM
chasboy's Avatar
chasboy
Oldtimer
Mike, there are lots of cars up here. Drive some more. That one seems like a lousy one I saw at a RT 3 dealer. Check with local clubs as well. There's North Jersey CC, Staten Island has a big club and there is another big one in Bergen County I believe.
Old Nov 9, 2011 | 11:27 PM
michael c. volpe
where on route 3?
just curious.
thanks for the input.
By Michael S. Palmer | 2026-06-03 11:00:24
