Tire question
Old Nov 12, 2011 | 08:25 AM
duke nukem's Avatar
duke nukem
Default Tire question
Hi guys, I just bought new wheels, Its a 19/20, 9,5" 11"
My question is this: will I have any issues with 35 profile both rear and front, I wonder if 35 profile is to high, what do you guys think
Old Nov 12, 2011 | 08:55 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The "MAIN" thing is keeping the height of the tire close to the stock height!
It can vary a 1/2" and not mess with the sensors, so don't go below 26" in tire height and you will be fine
Thanks,Matt
Old Nov 12, 2011 | 08:58 AM
romeokc10's Avatar
romeokc10
Sensors? What sensors are you talking about?
Old Nov 12, 2011 | 09:03 AM
madmatt9471
Each wheel has a sensor = Wheel Speed Sensor and "IF" the tire height is too tall or too short the wheel speed sensor will be set off -
Codes and lights will pop up to inform the driver on the DIC
Thanks,Matt
Old Nov 12, 2011 | 12:40 PM
duke nukem's Avatar
duke nukem
Thanks,Matt
Ok so that sould be my only consern or should I worry about some other issues?
Old Nov 12, 2011 | 02:19 PM
johnpowe's Avatar
johnpowe
Check this thread out. It gives a good overview of keeping the correct stagger front to rear to prevent problems with the AH/TC system.
http://forums.corvetteforum.com/c5-g...ah-issues.html
Old Nov 12, 2011 | 05:55 PM
madmatt9471
Thanks,Matt
Old Nov 12, 2011 | 06:09 PM
DBL98COR's Avatar
DBL98COR
I am running Nitto555
245/35/19 front
285/30/20 rear
No problems at all.
Old Nov 13, 2011 | 05:32 AM
duke nukem's Avatar
duke nukem
good thread
thanks very much for the info guys
Old Nov 13, 2011 | 11:09 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
good thread
Toque
Old Nov 13, 2011 | 12:55 PM
duke nukem's Avatar
duke nukem
One more qustion, if I would have some problems with AH/TC because of to high wheels could it be corrected with HP tuners or some kind of tuning computer?
Old Nov 13, 2011 | 03:26 PM
Toque's Avatar
Toque
I'm not sure about that.... Might want to ask a Tuner.
Toque
To Tire question
