Battery Life
But with that said, I would go ahead change it out if it were me. 7 years is pushing it and it seems nowadays with our electronics when they die they die in an instant. Doesn't seem like we get the usual warnings of a dying battery like we used to.
I just went down to my garage and fired up my old DOS based maintenance program .that I keep records of all my cars on and the last battery I purchased was in 2001 ..and it was for my 72 ...
I also use a 12v 35 Ah mobility scooter battery to power my telescope in my Slotted Domed Observatory in my backyard.. That Battery was used for over a year in a mobility scooter and charged and discharged almost every other day Its been in use in my observatory now going on 6 years ...I keep a battery tendar on it when not in use...
I'd just have it checked... ..Observatory has a dozen electrical outlets in it but I will NOT power my scope off of an AC adapter as ..my electric company is not the greatest I just do not need a voltage spike to fry the scopes electronics...
Now maybe I'm extremely lucky OR Battery Tenders prolong a batteries life
Bob G..
Bob G..
You have a lead acid battery if it's the OEM battery. The last ones in the 04s were redesigned so you don't have the risk of leaking which plagued the 97-00 batteries. That was caused by a bad battery post design which cracked if it was over-torqued. The AGMs fitted to the 02/03s were prone to early failure and you obviously don't have that issue
So, I'd say it depends how difficult a roasdside failure would be for you? If you drive within easy reach of home and have AAA, maybe you could live with the risk?
Normally, the battery gives a clue when it's about to die. Things like memory settings or HUD settings start to default to factory settings as the voltage drops.
Check your battery to see how it's doing:
To check your battery voltage, do not read the DIC when the car is off. The voltmeter is designed to measure alternator output when the car is running. It will always measure an inaccurately low voltage on the battery when the car is off. Anything from 11.0-11.9 is not abnormal in this mode. With the engine on, the voltmeter should show between 13V and 14.5V. A better reading can be measured at the battery terminals. Use a digital multi meter if you can. A fully charged battery measures 12.66 V and a fully discharged battery measures 11.86 V.
To be really accurate you should, first charge the battery fully (should be OK if you're on a tender) and then remove the surface charge. Leave the battery to sit at least several hours before testing. To remove surface charge the battery must be discharged for several minutes. Using a headlight (high beam) will do the trick. After turning off the light test the battery.
State of Charge, Specific Gravity, Voltage 12V
100% 1.265 12.7
75% 1.225 12.4
50% 1.190 12.2
25% 1.155 12.0
Discharged 1.120 11.9
When you look for a replacement the shop manual quotes the GM spec for the Vette which requires a Cold Cranking Ampage (CCA) of 500A and a reserve capacity of 80 minutes
How about buying a new battery and leaving it in the garage until you need it? You already had good service from your stock battery so I agree it won't be long before you need a replacement.
My original in my 04 died this spring.
