Dead Optima battery question
Old Nov 14, 2011 | 02:17 PM
SLO VETTE's Avatar
SLO VETTE
Default Dead Optima battery question
I've barely driven my car this year (maybe 50-100 miles, tops), and put in a new Yellow Top last December or so. Car's been parked with battery connected, no trickle charger.
Each time I've driven it (once in spring and once yesterday) the battery was dead. I started it each time with a booster pack.
I recently bought a trickle charger and had it on 2 amp slow charge for about 14 hours, and it did nothing.
Is the battery toast? If I went out and drove the car for an hour or two, would that re-charge it sufficiently?
Next time around, when I store it for long terms, I'll disconnect the battery completely. That's what I used to do on another Vette that was stored and never had a problem with it firing right up even after long spells of sitting.
Old Nov 14, 2011 | 02:38 PM
DeeGee's Avatar
DeeGee
Any battery would probably have died after such a long time and no serious driving to top it off.
You may have something drawing down on the battery. Dormant the car pulls 20 to 30MA so not surprising it's dead. It takes 20 mins to put back the drain from a start up. Do a draw check to be sure. Check out Bill Curlee's post in C5 Tech under the electrical sticky.
AGM batteries take longer to coax back to life when discharged although a Yellow Top is a deep cycle battery so it should be more resistent to discharge than a Red Top. I have to say, I'd expect a dead AGM battery to take up to 3 days to recharge fully on a trickle charger.
My Yellow Top sits around for weeks and starts first time but I wouldn't leave it months without putting it on the battery tender.
I'll dig out the advice from Optima which was posted here.
Old Nov 14, 2011 | 02:41 PM
DeeGee's Avatar
DeeGee
Default Recovering a Deeply Discharged AGM Battery
http://www.youtube.com/watch?v=dIoaL3DWWEg
Old Nov 14, 2011 | 02:45 PM
02HREBlue's Avatar
02HREBlue
I had a one year old yellow top Optima do the same thing. Never came back from a full discharge even with a battery tender and desulfation. Replaced with a red top, keep it on the battery tender if not driven over a week, and no problems at all. I thought a yellow top would be necessary with my big stereo, but the red top is the one doing the job just fine now. If doing it again, I would probably buy a top of the line Sears Diehard battery and be done with it. I know Optima has had periodic problems in batches of their batteries.
Old Nov 14, 2011 | 03:01 PM
Tech's Avatar
Tech
If you bought it from a local auto parts store, take it back. I've had a couple of friends (including myself) suffer from Optimas failing prematurely. We were able to exchange them where we bought them (Autozone, in 3 cases).
Old Nov 14, 2011 | 03:11 PM
dougbfresh's Avatar
dougbfresh
Car batteries are NOT deep cycle like marine batteries-1 or 2 complete discharges WILL kill them.
Old Nov 14, 2011 | 03:20 PM
DeeGee's Avatar
DeeGee
A yellow top is a deep cycle AGM. Thats why they cost so much
Old Nov 14, 2011 | 03:32 PM
SLO VETTE's Avatar
SLO VETTE
yeah it wasn't cheap.
i just want to know if i can (or if it's safe) to try & re-charge this thing, and if re-chargeable, what is best way of doing so.
otherwise i'll just pick up a new battery, and this time be careful to completely disconnect it if the car is going to sit for any longer than a few weeks.
Old Nov 14, 2011 | 03:36 PM
dougbfresh's Avatar
dougbfresh
Good (some weird) reading here:
http://www.optimabatteries.com/produ....php#deepCycle
Old Nov 14, 2011 | 03:39 PM
DeeGee's Avatar
DeeGee
Yes they will recharge and the best way is to put it on a battery tender for a few days. If its still under warranty you might just want to replace it though.
Old Nov 14, 2011 | 03:40 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
There is a specific method for recharging optimas involving hooking another battery in line with it while charging. I don't remember exactly the steps but it was outlined in the paperwork. Maybe the youtube link above describes it? You should be able to find the
information easily enough.
Old Nov 14, 2011 | 03:45 PM
DeeGee's Avatar
DeeGee
I have to say the only way to decide on the best battery for a Corvette owner is to look at his or her useage. I've had a leaky AC Delco, a good AC Delco, a Red Top which died in transit to England and a Yellow Top which is going well after 5 years. Would I buy a Yellow Top now? Probably not because there are cheaper batteries which wont leak on my PCM. that said, I've had 5 years of trouble and leak free service using a battery tender. And thats on a car that does 5k per year and sits for 2-3 weeks between use at times; someties on the tender and sometimes not.
Its horses for courses I'm afraid.
dougbfresh's Avatar
dougbfresh
It's all in the link I added above.
Old Nov 14, 2011 | 03:52 PM
heavymetals's Avatar
heavymetals
I junked my OPTIMAS and went to ODYSSEY batteries.
Much better.
Old Nov 14, 2011 | 04:06 PM
SLO VETTE's Avatar
SLO VETTE
anything's better than the initial batteries gm put in the vettes (the ones that leaked).
Much better.
Old Nov 14, 2011 | 05:05 PM
SLO VETTE's Avatar
SLO VETTE
Optima just got back to me on my inquiry on this topic, and they said charge it for 6 hours at 10 amps with my charger, then cycle the battery a few times (not sure what that means).
Will see if that works.
Old Nov 14, 2011 | 05:10 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
particularly a gel cell battery. if i remember correctly however there is a procedure to attempt to revive them. if you care, give it a shot. i agree if it is less than 1 year old, take it back to where you bought it and tell them you can't get it to hold a charge and you want it replace. they will tell you that they need to put it on their charger (usually for 1.5 to 2 hours) and run it on their battery analysis equipment to determine it is really bad. after that, they will replace it under the warranty.
Old Nov 15, 2011 | 05:12 PM
SLO VETTE's Avatar
SLO VETTE
Well, the recharging technique was a bust.
After 6 hours it was still completely void of any juice, and the battery got really HOT.
(I had the car cables disconnected during all of this, by the way. It was just battery and charger connected to each other.)
So, time to get a new one.
Recommendations? At this point I don't really care about Optima, am guessing that something from the local Napa dealer (they sell Interstate batteries) would be just fine, no?
To Dead Optima battery question
