part question
Old Nov 18, 2011 | 07:49 AM
frankb's Avatar
frankb
Default part question
What do you call the black plastic that goes arounf the key called. The part that has ON, acc, start. the one on mine is broken and I would like to replace it. If someone has one I would buy it. Just don't know what it is called. I took my bezel out and most of the tabs were broke from the 1 st owner. Installed the column lock bypass and I 'm in the process of adding a sirius. So while I have it apart I wanted to put the black ring around the key switch. Thank's again for the help. Frank
Old Nov 18, 2011 | 08:37 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Ignition bezel?
Old Nov 18, 2011 | 02:27 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by Mr.Bill
Ignition bezel?
i believe it is the ignition SWITCH bezel
Old Nov 18, 2011 | 02:58 PM
DeeGee's Avatar
DeeGee
Now this is sad but this is the part you need. Its an ignition bezel.
Speak to Bob at Fichtner Chevrolet
Old Nov 18, 2011 | 05:57 PM
frankb's Avatar
frankb
Thank you, I looked all over for this part. I check alot of the venders and found nothing. Thank you
To part question
