Front height adjustment
Old Nov 19, 2011 | 12:26 AM
Suthunman's Avatar
Suthunman
St. Jude Donor '14
Default Front height adjustment
I've searched the adjustment threads and understand the adjustment process. Can the adjustment bolt be reached fairly easy by simply jacking the car up using a puck and removing the wheel? I read that different suspensions do make a difference in how easy it is. I don't know the number of what I have, but it is an 03 model with the tour/sport switch on the console. I appreciate any input anyone may have.
Old Nov 19, 2011 | 02:34 AM
Last C5's Avatar
Last C5
All C5 suspensions are the same when it comes to the height adjustment bolt at the end of the spring. The tour/sport switch just controls the valving on the shock. Yes, jacking the car up and removing a wheel will give you access to the adjustment bolt.
Old Nov 19, 2011 | 02:38 AM
Suthunman's Avatar
Suthunman
St. Jude Donor '14
Thank you.
To Front height adjustment
