[Z06] Settle An Arguement
Advice would be appreciated.
http://www.youtube.com/watch?v=FquFrOalAAY
That is my .02 for whatever it is worth,
Sid
As far as issues with the clutch, I always downshifted on my last supercharged z06 with the stock 50k mile clutch. Not a single issue.
but It's still a good time and fun to practice your heel toe technique even when you are doing that the brakes are doing the stopping and you shouldn't even feel a tug when the clutch is released
I love listening to the engine unwind, so I typically brake while leaving it in gear, then pop it into neutral when I get down around 1k rpm before coming to a stop. As others have said, brakes are designed for slowing down; might as well use them for that purpose instead of all this unnecessary shifting.
Call it the potential of maybe the need for a little more rear brake bias, but regardless, the fact is I can decrease stopping distance with heel-toe downshifting versus braking only on approach.
As fars as the arguement goes, if your downshifting and releasing the clutch forcing it to reaccelerate the engine, then yes, you are increasing wear by doing it. If you can rev-match at minimum, or heel-toe at best, wear is quite minimal. I will add though, decelerating a motor from higher rpm is more strenuous on the engine internals due to the lack of resistance on the piston during the exhaust stroke.
Point is, if I had to make a true judgement I would say coasting to a stop certainly places less wear upon your drivetrain components. With that said though, I heel-toe on the street (more or less toe-toe during street driving using the side of my foot during light braking) and always will, as that's how I've always driven. I'll heel-toe anything...my friends laugh sometimes when they see me heel-toe a toyota pickup or something...lol...just habit. Sometimes I'll go to neutral if I'm certain I need to stop, but if there's a chance the light will change, I'm heel-toe downshifting in preparation to go back on the move.
. I got news for people though, you're not gonna be replacing trannys from downshifting on the street approaching red lights.
