Dash glare
Old Nov 25, 2011 | 01:37 PM
jcsperson's Avatar
jcsperson
NC Events Coordinator
Default Dash glare
I recently purchased an '01 coupe and have put 400 miles on it in a hurry while getting familiar with it. One thing I encountered today was a tremendous amount of glare off the dash as I headed east into the morning sun.
Do all C5s have this or did the previous owner use some kind of gloss dressing on the dash? Is there anything that can be done about it short of getting one of those cheesy dash protector covers? Is there a dressing product that will matte out the dash?
Old Nov 25, 2011 | 01:38 PM
hotwheels57's Avatar
hotwheels57
http://forums.corvetteforum.com/car-care-discussion-10/
Old Nov 25, 2011 | 01:42 PM
jcsperson's Avatar
jcsperson
I had 303 on my shopping list for the weather seals. I'll try it on the dash. Thanks!
Old Nov 26, 2011 | 12:27 AM
My guess is the previous owner used some protectant on the dash - the dash in my car is not glossy.
Old Nov 26, 2011 | 01:22 AM
Txsailor's Avatar
Txsailor
I wonder if the windshield for the HUD glares more than a regular windshield. It would make sense because it reflects the display.
Old Nov 26, 2011 | 01:43 AM
striper's Avatar
striper
Get polarized sunglasses, they will kill the glare and reflections. There are vinyl dressings that will specifically give matte finishes.
Old Nov 26, 2011 | 08:27 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, anything on there that will reflect light, will cause the glare.
Old Nov 26, 2011 | 10:33 AM
jrose7004's Avatar
jrose7004
No doubt.
Old Nov 26, 2011 | 10:36 AM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by jrose7004
No doubt.
Old Nov 26, 2011 | 10:45 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I just had my door panels repaired on my 2004 vert. I had the original OEM vinyl removed and new custom vinyl and SEM gray dye applied. As a common problem with C5s, the vinyl was separating and pulling away from the door foam around the arm rests.
When we pulled off the OEM vinyl, the OEM foam that failed fell off the door frame like hardened suger cubes. The auto upholstery shop I worked with told me this was due to protectants such as Armor All penetrating the vinyl and then breaking down the OEM foam and adhesive.
I admit that when I first purchased my 2004 vert that I used Armor All until I learned better and became aware of higher quality automotive products.
I also asked about the dash and other vinyl components and he told me it's always best to clean these areas with nothing but warm water and maybe a little soap if they are indeed dirty. After wiping the area and then drying it, a small amount of 303 or other protectant is recommended. I like 303 because it leaves a nice satin finish vs. the high glossy/reflective finish common with other products and does not contain the harsh chemicals that may damage the vinyl.
If you notice any gas film build up on the windshield, you used too much.
Old Nov 26, 2011 | 11:21 AM
chasboy's Avatar
chasboy
Oldtimer
what's 303?
I gave up on Armorall YEARS ago. I couldn't stand the 'feel' of it. I only use it for tires and when that runs out, I'm done.
Old Nov 26, 2011 | 11:28 AM
MSG C5's Avatar
MSG C5
Originally Posted by chasboy
what's 303?
Great stuff! Sold by forum vendor AutoGeeks...
http://www.autogeek.net/16oz.html
Old Nov 26, 2011 | 11:29 AM
LS2NSUV's Avatar
LS2NSUV
what's 303?
Check out post #2(click)and look at the dash product thread.
I type too friggin' slow. Check above post.
Old Nov 26, 2011 | 06:01 PM
chasboy's Avatar
chasboy
Oldtimer
Old Nov 26, 2011 | 09:33 PM
andynpz's Avatar
andynpz
Old Nov 26, 2011 | 10:35 PM
02koolC5's Avatar
02koolC5
I don't use anything on my dash, and in some locations and time of day the glare is quite bright, so i did put on the dash mat.
Old Nov 26, 2011 | 10:54 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I ended going with a Dash Mat, It comes out fast when needed and is a life saver during the day.
Tried the bottled stuff and none of seemed to work.
To Dash glare
Old Nov 26, 2011 | 11:54 PM
SuperDave02's Avatar
SuperDave02
I got one of those cheesy dash covers, came with my car when I bought it, and I like it. I dont have the glare. Also have about 8 inches of tint at the top of my windshield.
Old Nov 27, 2011 | 03:46 AM
GHL4505's Avatar
GHL4505
I like the dull black that came from the factory. I tried a product that was supposed to protect the vinyl one time. It left a shine, which I didn't like, so did some research on how to remove the product. Think it was a formula of five parts water and one part dish soap. A couple of towels and wipe on wipe off kind of thing turning the towel often. That technique worked just fine and the shine was gone and it was back to the factory look.
Old Nov 27, 2011 | 08:40 AM
chasboy's Avatar
chasboy
Oldtimer
I first read that as "8 inches of LINT"Don't mind me, I need new glasses!!
