Cold oil change?
Sorry, it doesn't work that way. ALL oil thins as it gets hotter, it matters not what the initial weight listing is. A multi-weight oil is engineered to flow as a light weight oil when cold and then flow like a heavy weight oil when hot. This is done with viscosity modifiers added to the base stock during manufacturing. Hope this helps a little.
Scott
