2000 DIC controls
The troubleshooting procedure just suggests changing the DIC switch. If it's plugged in properly and the connectors are clean and tight, looks like its a bad switch.
I have seen a couple posts where the problem was solved by replacing the IPC.
Document ID# 386774
2002 Chevrolet Corvette
________________________________________
Driver Information Center Switch Replacement
Removal Procedure
Notice
Whenever the Instrument Panel Cluster (IPC) is removed from the vehicle, DO NOT set the IPC on its face for more than 15 minutes or damage to the fluid filled air core gages may result.
1. Remove the instrument panel cluster (IPC) from the vehicle. Refer to Instrument Panel Cluster (IPC) Replacement .
2. Disconnect the instrument panel (IP) dimmer switch or the IP dimmer/head-up display (HUD) switch electrical connector.
3. Disconnect the driver information center (DIC) switch electrical connector.
4. Remove the IP cluster bezel retaining screws.
5. Remove the bezel from the IPC.
6. Remove the DIC switch retaining screws.
7. Remove the DIC switch.
Installation Procedure
1. Install the DIC switch to the IP cluster bezel.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the DIC switch retaining screws.
Tighten
Tighten the DIC switch retaining screws to 1.5 N•m (13 lb in).
3. Install the bezel to the IPC.
Align the bezel onto the guide pins.
4. Install the IP cluster bezel retaining screws.
Tighten
Tighten the IP cluster bezel retaining screws to 1.5 N•m (13 lb in).
5. Connect the IP dimmer switch or the IP dimmer/HUD switch electrical connector.
6. Connect the DIC switch electrical connector.
7. Install the IPC to the vehicle. Refer to Instrument Panel Cluster (IPC) Replacement .
Remove Console using Vette Essentials instructions:
http://www.vetteessentials.com/instr...brake_h_b.html
Removal Procedure
Notice
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
1. Disconnect the negative battery cable.
2. Remove the I/P upper trim pad. Refer to Trim Pad Replacement - Instrument Panel (I/P) Upper .
3. Carefully lift the head-up display (HUD) electrical harness from between the instrument panel cluster (IPC) and the HUD, if equipped.
4. Disconnect the HUD electrical connector from the IPC, if equipped.
5. Remove the retaining screws that secure the IPC to the steering column bracket.
6. Raise the rear of the IPC slightly to release the locator tab, then lift the IPC to access the electrical connector.
7. Disconnect the IPC electrical connector.
8. Remove the IPC.
1. Connect the IPC electrical connector.
2. Position the IPC to the steering column bracket.
3. Verify that the IPC retaining tab (1) is positioned correctly to the steering column bracket (2).
Notice
4. Install the retaining screws that secure the IPC to the steering column bracket.
Tighten
Tighten the retaining screws to 3 N•m (27 lb in).
5. Connect the HUD electrical connector to the IPC, if equipped.
6. Carefully tuck the HUD electrical harness (1) down between the IPC and the HUD as shown.
7. Install the I/P upper trim pad. Refer to Trim Pad Replacement - Instrument Panel (I/P) Upper .
8. Connect the negative battery cable.
Tighten
Tighten the bolt to 15 N•m (11 lb ft).
9. Program the transmitters. Refer to Transmitter Programming in Keyless Entry.
10. Synchronize the transmitters. Refer to Transmitter Synchronization in Keyless Entry.
Removal Procedure
1. Remove the console. Refer to Console Replacement .
2. Remove the IP accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory .
3. Remove the driver knee bolster trim panel. Refer to Trim Panel Replacement - Knee Bolster .
4. Remove the instrument panel compartment. Refer to Compartment Replacement - Instrument Panel (I/P) .
5. Remove the windshield defroster grille. Refer to Defroster Grille Replacement .
6. Insert the DRL and sunload sensors, if equipped, into the nearest openings in the windshield defroster duct.
Moving the sensors into the defroster duct provides additional clearance to remove the trim pad.
7. Remove the windshield side garnish moldings. Refer to Windshield Side Garnish Molding Replacement in Interior Trim.
8. Remove the screws retaining the upper trim pad to the defroster duct.
9. Remove the screws retaining the upper trim pad to the LH and RH hinge pillars.
10. Remove the screws retaining the IP cluster bezel to the upper trim pad.
11. Remove the screws retaining the upper trim pad to the driver knee bolster outer bracket and the center support bracket.
12. Remove the screw retaining the upper trim pad to the passenger SIR bracket.
13. Tilt the steering wheel to the lowest position.
14. Lift the rearward edge of the upper trim pad approximately 5 cm (2 in) to provide clearance for the air distribution duct located on the underside of the trim pad.
15. SLOWLY pull the upper trim pad away from the windshield while guiding the tabs on the LH and RH side of the trim pad past the hinge pillars.
16. Disconnect the hazard warning switch electrical connector.
17. Remove the upper trim pad from the vehicle.
1. Connect the hazard warning switch electrical connector.
2. Install the IP upper trim pad into position.
A. Tilt the forward edge of the trim pad down slightly.
B. SLOWLY begin to move the trim pad into position while guiding the tabs on the LH and RH side of the trim pad past the hinge pillars.
C. Locate the trim pad by guiding the alignment notch on the underside of the pad onto the alignment pin on the dash panel.
D. Lower the rearward edge of the pad into place.
Remove the DRL and sunload sensors, if equipped, from the openings in the windshield defroster duct and position above the trim pad.
Notice
Install the screws retaining the upper trim pad to the windshield defroster duct.
Tighten
Tighten the IP upper trim pad to windshield defroster duct screws to 1.9 N•m (17 lb in).
Install the screws retaining the upper trim pad to the LH and RH hinge pillars.
Tighten
Tighten the IP upper trim pad to LH and RH hinge pillar screws to 2.5 N•m (22 lb in).
Install the screws retaining the upper trim pad to the driver knee bolster outer bracket, the center support bracket and the passenger SIR bracket.
Tighten
o Tighten the IP upper trim pad to driver knee bolster outer bracket screw to 1.9 N•m (17 lb in).
o Tighten the IP upper trim pad to IP center support bracket screws to 1.9 N•m (17 lb in).
o Tighten the IP upper trim pad to passenger SIR bracket screw to 1.9 N•m (17 lb in).
Install the screws retaining the IP cluster bezel to the upper trim pad.
Tighten
Tighten the IP cluster bezel to IP upper trim pad screws to 1.3 N•m (12 lb in).
Install the windshield side garnish moldings. Refer to Windshield Side Garnish Molding Replacement in Interior Trim.
Install the windshield defroster grille. Refer to Defroster Grille Replacement .
Install the instrument panel compartment. Refer to Compartment Replacement - Instrument Panel (I/P) .
Install the driver knee bolster trim panel. Refer to Trim Panel Replacement - Knee Bolster .
Install the IP accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory .
Install the console. Refer to Console Replacement .
http://forums.corvetteforum.com/c5-t...cycling-2.html
This C5 is a whole new adventure in driving and repairs. I will likely let a dealer fix this DIC issue, but I want to know what should be done before I let them. I bought 100% mechanical coverage that covers me for another 60K miles when i bought the car from a dealer just in case this type of thing happened to an 11 year old car. I think it will pay off.
Thanks again, and I will report back when done.
