[Z06] Underdrive Pulley's
Old Dec 3, 2011 | 10:41 PM
Woodytick's Avatar
Woodytick
Default Underdrive Pulley's
so i've been doing some research on Underdrive Pulley's & i'm wondering what some of you guys might be running. i checked out the ones on TSP & a few other sites & wanna know which one will be the best bang for my buck. you input would be great.
Old Dec 3, 2011 | 11:10 PM
81c3's Avatar
81c3
Power Bond 25% UD It was right around $200. made in Austrailia. Nice piece and alot of guys run these with no problem.
Old Dec 3, 2011 | 11:16 PM
TXGS507's Avatar
TXGS507
Running ASP w my H/C/I....
Old Dec 4, 2011 | 10:41 AM
Woodytick's Avatar
Woodytick
i was looking at te ASP pulleys on TSP, both the Balancer & the Alternator pulley. did you notice much after swap? i just did the rebuild not long ago & did a few things like a cam, intake, exhaust. just trying push as much power as i can before i do the heads next summer.
Old Dec 5, 2011 | 02:18 PM
PRE-Z06's Avatar
PRE-Z06
Usually good for ~8rwhp
Old Dec 6, 2011 | 11:53 AM
Matt@Texas-Speed's Avatar
Matt@Texas-Speed
Premium Supporting Vendor
Like mentioned above, they are typically good for about 7-9rwhp and are very inexpensive! Under $250 if you can do the labor yourself!
http://www.texas-speed.com/c-207-pulleys.aspx
__________________
Largest Stocking Distributor of LS-x Engines / Largest LS-x Comp Cams Distributor in the Country!
COMP - FAST - PACESETTER - CALLIES - COMETIC GASKETS - MONSTER CLUTCHES - MOSER ENGINEERING - KOOKS
ARP - GM BOLTS AND GASKETS - MSD - NGK - POWERBOND - WISECO - ASP - AND MORE!
Old Dec 6, 2011 | 04:21 PM
Woodytick's Avatar
Woodytick
oh i can do all the work myself, when rebuilt my engine a cew months ago, all of my internal parts came from you guys so thats where i will purchase this from as well.
To Underdrive Pulley's
