Problem!!!! MPH/KPH going crazy
Old Dec 7, 2011 | 07:41 PM
350z4lyfe's Avatar
350z4lyfe
Default Problem!!!! MPH/KPH going crazy
So randomly my thing changes to mph and kph automatically really crazy.
My buttons on the side don't work when that's happening. (reset, trip, E/M etc)
any help?
thanks
Old Dec 7, 2011 | 08:17 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Sounds like you need a new DIC switch. A button is getting stuck.
Old Dec 7, 2011 | 08:51 PM
Dag Skagney's Avatar
Dag Skagney
My car was built for Canada sale and would reset to KPH at almost every ignition cycle. I figured it had a weak battery as it had set up for almost a year before I got it. I would just reset to MPH but it did bug me. When i finally got around to pulling battery out to have checked at local auto store I noticed that the battery terminals were quite loose. I suppose at some point the battery was disconnected and when reconnected terminals were not tighthed. Anyway bettery tested and only had about 40% life left. I got a new battery, installed, tightend connections and no trouble since. It stays on MPH. From what you describe this is likely not your problem but might be worth a look anyway.
Old Dec 7, 2011 | 10:58 PM
I agree - check battery first, then if that proves OK, consider a new DIC switch.
Old Dec 7, 2011 | 11:09 PM
350z4lyfe's Avatar
350z4lyfe
Thanks guys....I will check it out tomorrow
To Problem!!!! MPH/KPH going crazy
