What is the diff between these two brass gear kits?
Old Dec 8, 2011 | 09:53 AM
Baibaikin's Avatar
Baibaikin
Default What is the diff between these two brass gear kits?
This brass headlight gear kit has the brace to prevent the gear case from prying open by itself.
http://forums.corvetteforum.com/c5-p...ight-gear.html
The brass headlight gear kit from Corvettemods does not have the brace.
I'm confused, which one should i get?
Old Dec 8, 2011 | 09:55 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I bought one from Rodney years ago no issues...but mine was for a 99 and the earlier headlight motors are different in the way they are put together perhaps that is why you have differences in kits...
Old Dec 8, 2011 | 10:53 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Get the one with the brace from Rodney Dickman.
With the brace, the motor casing has no chance of coming apart, ever.
Old Dec 8, 2011 | 11:57 AM
sarrojm's Avatar
sarrojm
My car was modified prior, to my ownership, without the brace and the case glue failed. So get the one with the brace
Old Dec 8, 2011 | 01:20 PM
blacksedan87's Avatar
blacksedan87
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Early cars (97, 98, 99) had screws that held the case halves together. It is not necessary to use the brace. Later cars - 00 through 04, the case was sealed and glued. The brace is a major improvement over simply gluing the halves together.
Old Dec 8, 2011 | 01:31 PM
Txsailor's Avatar
Txsailor
Darn I didn't know about the brace and have two without it that I was going to install in my '04 for preventive maintenance. How hard would it be to make the brace? Does anyone have a template or a drawing?
Old Dec 8, 2011 | 01:46 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Rodney sells the brace and adhesive separately as well. I think about $7
Old Dec 8, 2011 | 02:30 PM
Txsailor's Avatar
Txsailor
Found it
Old Dec 8, 2011 | 05:35 PM
Never really knew that - thanks for the heads-up.
To What is the diff between these two brass gear kits?
