low coolant message in DIC
Old Dec 10, 2011 | 05:26 PM
jlbsam's Avatar
jlbsam
Default low coolant message in DIC
am getting this message, but pretty sure there is plenty of coolant in the rad. the surge tank is 1/2 full. should i be worried?
Old Dec 10, 2011 | 06:05 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
possible bad float in the tank.
Low coolant message comes from the side tank, not the radiator.
Check connection at the float then check and see if float is stuck or bad.
To do that, just unplug the float wiring and short the 2 wires out with a paper clip, if the message goes away, then it's your float.
Old Dec 10, 2011 | 06:44 PM
jlbsam's Avatar
jlbsam
Default low coolant
i just replaced the surge tank a few weeks ago. just checked it over and on the front of the tank there is a line indicating "full cold" and the level was not up to that point, so i filled the tank. will see if the message goes away now.
Old Dec 10, 2011 | 06:50 PM
If it doesn't, do like was said above - check the sensor in the overflow tank.
Old Dec 10, 2011 | 06:51 PM
steveovette's Avatar
steveovette
Ha thats funny.
We always assume the worst.
I guess the low coolant light was doing it's job eh.
To low coolant message in DIC
